Old February 8th, 2020, 06:51 AM
Ec4fish Ec4fish is offline
Ec4fish is a Soldier
Default Interior floor covering
Hey guys: what have you all done for covering your interior floor pans, and transmissions?
Mine had a felt type underlined and whole cab rubber matting. The felt type product absorbed some water from leaks in the cab area over the years. The rust it caused has been taken care of, but Id like to put a covering back in.
It had a rubber type mat. Id kind of like to do something like that again, but cant seem to find anything like it. Also thinking of using a Mylar type sound deadening product.
What have you used, and where did you source it from. By the way, this is for a cab of a 725.
Old February 9th, 2020, 02:17 PM
TJinSD's Avatar
TJinSD TJinSD is offline
TJinSD is a Soldier
What luck!
1968 M-715 w/1100R16s on Stockton wheels, H3 headlights, 2bbl upgrade...
Old February 9th, 2020, 07:48 PM
Thanks, will look it up. How did it fit?
Old February 9th, 2020, 08:37 PM
TJinSD's Avatar
TJinSD is a Soldier
It was plenty big enough. Molded for the ridge in the back of the cab. The downside is that everything has to be cut out. It came with a felt liner that covers the center of the floor and cuts down a lot of noise and heat. The vinyl is thicker than I thought it would be. It should last a long time. If you look around their website you should be able to find a picture of it. I don't know why they make it so hard to find more than just a little color choice picture.
Just now going through my pictures, and I guess I didn't take a single one while I was installing it.
Old February 10th, 2020, 07:06 AM
kwai's Avatar
kwai kwai is offline
Sergeant
kwai is a Soldier
I always remove any floor coverings because of the moisture problem. because the cab is not sealed, the carpet/mats just create rust. If you are storing the truck indoors it would be less of a problem.
  #6
Old February 10th, 2020, 07:41 AM
TJinSD's Avatar
TJinSD is a Soldier
Thanks for the info, kwai. I'll check for trouble spots when I get a chance.
