Results 1 to 10 of 10
Thread: weird turn signal problem
    front turn signals work fine.
    left turn signal on, no left rear.
    right turn signal on, rear hazards on.
    hazards on, rear hazards on. again the fronts work correctly. all bulbs are good. they worked till last week, that i know of. any ideas?
    i did find that an inproper front signal ground causes VERY weird light problems
    FYI the 24 volt flasher and turn signal control work fine on 12 volts.... and its waterproof
    Default Free 230 engine, complete with accessories
    Thats the later style, non giagantic distibution box type, thats working on 12 volt right?
    Did you check the rear light wires for continuity to ground...possible short somewhere...though you have new wiring dont ya?
    Sounds pretty goofy to me...
    yeah, new wiring....
    also i do have the late style cigarette pack size solid state flasher.
    im guessing something must be loose, i replaced the turn signal switch, no help. maybe the flasher is bad?? its solid state so who knows
    Maybe trhow a little dielectric grease in all the connections and see if it helps....a thought...
    West-central Ohio
    Sounds all the world like a bad ground. You're on the right track...
    Mar 2004
    Stinnett Tx
    I would agree with bump_r on the possibility of a bad ground BUT you say you have new wiring.. Did the problem start when you put the new wireing in or had the wireing been in for a while?? If the problem started when you rewired it then I would think you wired the Right turn signal into the rear marker lights..
    My trailer lights when crazy on my a couple of weeks ago. It was a bad ground causing backfeeding all over. Most like what you have.
    Big Blocks RULE!
    no its been working since feb, till last week
    Ground!!! Put internal/external star washers on your bolts to your lights. I have seen that many times, Also the flasher box should have three wires going to it in the connector and one of them should be to ground. Make sure it's grounded real good.
    Zone holster maker
    parsons Kansas
    Im fighting some ground problems on mine right now. mostly where they bolt up but my wiring is bad at the rear lights too and broke wires that needed repairing.
    67 M725, 67 M715, 68 M715
  1. Turn Signal Switch
    By fng in forum Modified Tech
    Last Post: December 9th, 2012, 09:43 PM
  2. My turn signal blinker is.........
    By viperman in forum Stock Tech
    Last Post: June 24th, 2008, 03:56 PM
  3. Turn Signal Distribution box.
    By Kaisercal in forum Open Discussion
    Last Post: May 28th, 2008, 07:48 PM
  4. Wiring problem with new turn signal block
    Last Post: April 23rd, 2007, 09:38 AM
