  #1
Old May 7th, 2018, 09:29 AM
Uncle Vin Uncle Vin is offline
Private
Uncle Vin is a Soldier
Default Winch PTO shaft bearing retainer
Can someone post a pattern for the winch PTO shaft bearing retainer bracket? Mine was modified and I want to return it to stock specs. I thought that Surplus City had some, but they are out. I've also checked all of the other usual parts suppliers.
  #2
Old May 10th, 2018, 07:00 AM
Private
Bump
  #3
Old June 20th, 2018, 07:27 AM
Private
Bump
  #4
Old June 20th, 2018, 05:09 PM
Jonnie's Avatar
Jonnie Jonnie is offline
Private
Jonnie is a Soldier
I can help, I'll have to dig mine out of a box.
__________________
Jonnie
  #5
Old June 21st, 2018, 09:17 AM
Private
Quote:
Thanks Jonnie. We (the site) should then make it a Sticky.
  #6
Old July 22nd, 2018, 05:57 AM
Private
Any luck with this?
  #7
Old July 22nd, 2018, 09:09 AM
Jonnie's Avatar
Private
Jonnie is a Soldier
https://imgur.com/a/s5xJf
Try this, it started as a PDF which I can email to you.
__________________
Jonnie
1998 - 2019
Copyright 1998-2019
