Go Back   M715 Zone > General Tech > Stock Tech > Stock Tech Archives
Stock Tech Archives Look here first for all archived messages
  #1
Old February 19th, 2004, 04:26 PM
jeeplightman jeeplightman is offline
New Recruit
jeeplightman is a Soldier
I'm resealing my NP200 transfer case for the 2nd time in a year due to leaks. I used NOS seals from AB linn. The surfaces on the yokes were not grooved to bad. Can anyone tell me were I'm going wrong? Should I use NOS again or are there better seals out there?
Thank in advance
Marc
  #2
Old February 19th, 2004, 04:40 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Bump_r posted that you can get seals from parts stores but that they are not as good as the NOS ones from AB Linn...see the M715 Parts list in the Online manuals linked on the left side if you want more info...sounds Like AB is A+...as usual.
__________________
  #3
Old February 19th, 2004, 06:08 PM
LuckyPabst's Avatar
LuckyPabst LuckyPabst is offline
Private 1st Class
LuckyPabst is a Soldier
Marc,
I prefer new manufacture rubber versus NOS in all cases. But you said the surfaces weren't grooved that bad - are they grooved at all? Minor roughness will eat a seal pretty fast.
I replaced a pinion seal and the surface wasn't grooved that bad but it began leaking very quickly. The easy fix was a redi-sleeve, a good parts store will know what you're talking about. If you think you need one, just order according to the seal number you're using. They aren't exactly cheap at 18ish bucks but they work.
  #4
Old February 19th, 2004, 06:25 PM
brute4c's Avatar
Grand Poobah
The new manufactured ones are thinner metal and nowhere near the quality in the rubber of the NOS ones...that why they are preferred.
The redi sleeve part numbers are listed in the parts file linked on the left in the online manuals section.
If the mem pics were worring at the moment, you could see the big difference between the NOS and newer seals...it is dramatic.
__________________
  #5
Old February 19th, 2004, 07:59 PM
Nuke_mcinfantry Nuke_mcinfantry is offline
Private
Nuke_mcinfantry is an Observer
i called the company listed on my seal, and he said they still make the seal. current rubber, with the extra felt seal too. he did say its not stocked by alot of dealers... the felt keeps mud off the rubber.
__________________
1967 M-715 (A1)
www.homepage.mac.com/ltalessi
  #6
Old February 19th, 2004, 10:58 PM
Kaiserjeeps's Avatar
Kaiserjeeps Kaiserjeeps is offline
Sergeant
Kaiserjeeps is a Soldier
Can I hijack this thread in the most militant way? Has anybody ever replaced the shift rail seals with the Xfer in the rig? I'm to lazy to go out side and see if it can be done....
  #7
Old February 20th, 2004, 03:47 PM
New Recruit
Thanks everyone for the Info.
I think I'll go with the NOS seal and the readi sleeves and be done with this leaking.
Thanks again
Marc
  #8
Old February 20th, 2004, 05:20 PM
LuckyPabst's Avatar
Private 1st Class
Al,
I have the case completely disassembled and I still can't get the rail seals out. Maybe you can puncture the edge of it and pry it out but I bet it'll be hella difficult without mangling something else.
  #9
Old February 20th, 2004, 10:46 PM
Sergeant
Default cuda
Hmmm, thanks Chris... Thats what I was wondering.
HTML code is On
transfer case ? d4colombo Modified Tech 31 September 11th, 2012 07:01 AM
ron : NP{200 Transfer Case PseudoZone PseudoZone - Open Archive 7 November 11th, 2009 03:04 AM
sparkles... in my transmission and transfer case case syzygy Stock Tech 10 November 29th, 2008 05:33 PM
Confronting transfer case heat, stock NP200 brute4c Open Discussion Archives 0 May 31st, 2007 07:08 AM
1998 - 2020
Copyright 1998-2020
