Results 1 to 10 of 12
Thread: Give me some ideas!
    Default Give me some ideas!
    So...I decided to keep the 715 a while longer. Looking for ideas for a slight rebuild to make it fresh and fun again.
    Basics: Cheby 350, AA Ranger O/D, T98 trans, NP200, stock axles, tubeless rims with XZL's. Dual-fuel (propane/gasoline). 2" body lift on cab & front clip.
    Parts I got sitting around, will go in eventually:
    CUCV axles (spring over? spring under? coil/4-link?)
    NP205
    Power Steering.
    I think I'll remove the propane...maybe ditch the carb, too, and do a DIY TBI on it.
    Here's what I got right now ('cept the top is UV rotted and gone)
    Ideas? Change the paint? What would y'all drop or add?
    DP
    Man invented the slowest form of transportation - the sailboat, Then decided to race them.
    how did you post the pictures.
    Feb 2007
    Bloomfield CT
    I would do the PS maybe the axles, not sure what your idea of "fun" is.....=
    Is that real money?
    Sep 2014
    Wichita Falls, TX
    Quote Originally Posted by tomb View Post
    Ditto that. Photobucket is holding all my pics hostage.
    Mirrors, top, maybe paint, big winch and a new front bumper situation, maybe a big block. The 205 and axles (4 link) and send me your old wheels and tires as a consulting fee.
    Quote Originally Posted by ray steadward View Post
    Fun is time in the shop!
    Sent from my SM-G930V using Tapatalk
    DP
    I have an account at smugmug.com for my photo and travel stuff. About 40 a year.
    DP
    Different paint, trailing arm coil-spring suspension like that on a G-Wagen or the front of a '66-'77 Bronco. THAT would be cool.
    I'm in process of doing:
    Cummins 5.9L, Ford ZF 5-Speed Manual, Ford NP205 swap
    Ford Dana 60/Sterling 10.25 Spring UNDER Swap
    Power steering, hydroboosted power 4 wheel disc brakes
    Hydraulic Clutch
    Relocated Fuel Tank to spare tire area
    12 Volt, all LED lighting
    M998 Mirrors
    All to basically say 10 feet away you won't be able to tell a difference.... unless its running or you count the lug nuts
    Sep 2014
    Wichita Falls, TX
    Quote Originally Posted by venominjected View Post
    That's where mine is, originally an M724. Don't like it. Been thinking of getting a stock tank and moving it to stock location... one of these days. Can I ask why you're moving yours? Maybe I should leave mine where it is.
    hmmm... Smugmug..
    Dp,
    The CUCV axle swap will make it feel like a different truck. More part throttle from a stop acceleration speed.
    I would suggest a spring under for the swap. I did the CUCV swap on the truck for Sermis spring over. With 12.50-20 tires (40"), the floor board is at my waist. You really have to want to get in the truck before you start that climb.
