Results 1 to 5 of 5
Thread: radiator help!
    Default radiator help!
    im new to the forum. i just got a m715 with a chevy 400 in it. it does not have a radiator. the truck is pretty beat up so i dont want to spend a lot of money on a radiator.. Is there any car that i can get a radiator out of that will fit well and cool that 400 good enough? thanks for the help
    400 Chevy engines are hard to cool compared to the rest of the small block family because of the water jacket design. About the only bolt in you will find is for a 396 Chevelle. Some trimming will be required even with that. Several companies offer 350 SBC swap kits for CJ jeeps. Those radiators are also as close to bolt in deals as you will find. Zoners that have used either option report good results.
    I have a Summit aluminum radiator in mine and love it. I had to move the support over, make mounts and a few other things however. My 396 Big Block does just fine in the Texas heat though.
    The other option is to run a core support from a 72-91 FSJ that had a V8 and run an aftermarket aluminum radiator that is set up for the GM V8. This is what I did with mine, works really well.
    1967 M715 w/ 454 and TH400
    so it looks like i am just going to have to bite the bullet and order a v8 conversion rad off ebay. what are the dimensions that i need?
    Just order a "CJ to V8 conversion radiator".
    Search that exact term on e-bay and you'll come up with several options. Aluminum or standard copper. I did the aluminum one and it cools my 396 just fine with an electric fan.
    Nice thing is, it fits in the stock space almost exactly. You just need to elongate the mount holes either in the radiator or body a tiny bit.
  1. Radiator
    By Mikel in forum Stock Tech
    Last Post: October 18th, 2009, 11:23 AM
  2. Again with the radiator
    By Tomahawk715 in forum Modified Tech
    Last Post: October 23rd, 2007, 02:47 PM
  3. Radiator for V8?
    By randyscycle in forum Modified Tech
    Last Post: July 22nd, 2007, 09:02 AM
  4. Radiator
    By GND_PNDR in forum Modified Tech Archives
    Last Post: January 25th, 2004, 12:31 PM
