  #1
Old July 8th, 2019, 10:23 AM
TJinSD's Avatar
TJinSD TJinSD is offline
Private
TJinSD is a Soldier
Default Dipstick
I keep being brought back to oil related problems, and I'm wondering if I have a modified gauge, indicator, oil, engine, manual... dipstick.
The reason for this is that if I fill the crankcase to the full line, the engine will throw out a quart somehow. The oil isn't going anywhere else, not in coolant, no smoke screen, not noticeable on the ground, but the oil pump/front pan seal area is wet and spreading on the left side especially. I tweaked the oil pump bolts just a touch, and snugged the oil pan bolts back down (up?).
So I'm suspicious of this dipstick. It's two pieces of different thicknesses of metal riveted together just inside of the stop.
Does anyone have a source for a replacement? Pictures of the correct one? I can't find even a picture anywhere. Or measurements. If you have the correct measurements from the stop to the end, and to the full mark I could at least know if I'm putting in too much oil.
Thanks to all once again!
__________________
1968 M-715 w/1100R16s on Stockton wheels, H3 headlights, 2bbl upgrade, original radiator upgraded to 3 row...
Last edited by TJinSD; July 8th, 2019 at 10:26 AM. Reason: Left out: Surplus Jeep does have it listed on their site. Doesn't seem to be available. That's all I've found.
  #2
Old July 8th, 2019, 10:34 AM
gonz's Avatar
gonz gonz is offline
Administrator
gonz has disabled reputation
I seem to recall an old story where the dip stick was correct, but the dip stick tube wasn't the correct length? Or the tube wasn't put in all the way, so the dip stick would measure low when it really wasn't. Whoever does the measurement, maybe post the tube length as well. My truck doesn't have the 230 or I'd measure both for you- gonz
__________________
Come and take it
  #3
Old July 8th, 2019, 11:31 AM
TJinSD's Avatar
Private
TJinSD is a Soldier
Quote:
Oh yeah, that's another possibility, but I did find one or two pictures of other engines that looked close to the same as mine, so I'm hoping that's not it. Thanks!
__________________
  #4
Old July 9th, 2019, 06:14 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
If you put 6 quarts in from empty with a new filter, run the truck for a minute to fill the filter well, then check the level...wherever the level is should be the point where full should be marked on a stock 230.
One way to get the level to a known point...
__________________
  #5
Old July 9th, 2019, 06:16 PM
brute4c's Avatar
Grand Poobah
TJinSD,
In your signature it says radiator upgraded to 3 row...stock the M715 is 3 row....
__________________
  #6
Old July 9th, 2019, 06:51 PM
TJinSD's Avatar
Private
TJinSD is a Soldier
Quote:
Originally Posted by brute4c View Post
TJinSD,
Is it really?? Then I suppose what I have wasn't original after all. It worked well at 2 rows though. I'll take that out of my signature when I'm back on the computer. Thanks for the info!
__________________
  #7
Old July 10th, 2019, 05:59 AM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
TJinSD,
I have to agree, my truck had/has a three row radiator. McCord is the brand I have. I had to have it re-cored for the obvious reason. Runs cool and I put the thermostat back in. (Missing when I got the truck) Temperature rises quickly (Florida) to 180F and stays there in parades or "high" speed (50 MPH ).
  #8
Old July 11th, 2019, 06:14 PM
brute4c's Avatar
Grand Poobah
Yep...the factory one is the mccord...
__________________
  #9
Old July 11th, 2019, 06:57 PM
TJinSD's Avatar
Private
TJinSD is a Soldier
I'll take a closer look. Mine is a mccord. I searched but wasn't able to find anything with the number that's on it. Now, thinking back to what the radiator guy said, he told me the core was listed in his book. I wasn't sure if he meant the mccord number, m715, Jeep or what. But I told him to put a 3 row in it if he could. Maybe he looked up m715 and ordered a replacement core, which was 3 row. I gave him what I thought was a factory 2 row, got a three row back. Looked like an upgrade to me!
__________________
  #10
Old July 12th, 2019, 07:51 AM
Don Cavey's Avatar
Staff Sergeant
I can tell you that the guy here in Jacksonville, FL took measurements of the core (original) and called a place in Texas and had a new core made to the measurements. He told me that it would be made out of virgin brass, no recycled Chinese junk. He got it in less than a week. It is perfect.
I realize that $350 is/was a lot of money. But some things in my mind just need to be right the first time.
(What comes to mind is the gas tank. I plopped down the bucks for a new stainless steel tank. No worries, no flaking, no clogging, it just works. My time is money and I don't want to be left on the side of the road)
1998 - 2019
Copyright 1998-2019
