Results 1 to 10 of 10
Thread: Using Civilian plug wires on the Military Distributor
    Thanks to Krob725, we now have a page that shows how civilian type plug wires can be adapted directly to the military distributor using co-ax cable end parts. It is online here:
    http://www.m715zone.com/manuals/tech...reconvert.html
    I will be putting a link to this page in the online manuals section linked at left for future reference.
    Default Using Civilian plug wires on the Military Distributor
    Sure, get me all excited and then the link doesn't work.
    Works fine for me...try reloading maybe...
  4. Default
    WOW! It's like I'm psychic, I will try to post pictures tonight. I did almost the exact same thing as described last week.
    1969 M715
  5. Default
    This is what I have done so far. I bought CB connectors at a local truckstop($1.65 ea.) and the tips are spark plug coil connectors for motorcycles,wires are from motorcycles also.(7mm copper solid core)
    I used plastic compression washers and silicon to seal and hold the wire,didn't really need to, the CB connector holds it really tight.
    Next is a (24v) Point-Less ignition ,fits perfect just need the right connectors and splice existing harness. I also found some braided casing that looks like original military wires, so I may cover the new wires to make them look stock(old?) It's some fun tinkering!
    1969 M715
    San Antonio,Texas
    NICE WORK DAN!
    K
    67 M725 84 GW
    Tell us more about this solid state pointless ignition you speak of? What is it? Where did you get it? How does it fit? Did you have to do alot of splicing? Pics Pics Pics ...tell us more...Will it work on 4 bangers as well?
    Zone holster maker
  8. Default Driving with no axleshafts?
    I just ordered the ignition, I used one (12V) previously on a Chevy 194 straight six and it worked perfectly. Local Hot Rod shop ordered it for me.
    $62 w/ tax. HEI conversion was looking alot more expensive! This keeps the Stock Look.
    1969 M715
    Thanks for the info....Something to ponder....
    Zone holster maker
    St Louis, MO
    These ideas are cool!
  1. Civilian Distributor ID#
    By rboltz in forum Modified Tech
    Last Post: July 11th, 2021, 05:31 PM
  2. Civilian Distributor Cap
    Last Post: October 4th, 2011, 11:05 PM
  3. Civilian Distributor
    By m16ty in forum Modified Tech
    Last Post: March 3rd, 2008, 01:53 PM
  4. plug wires
    By cnewman425 in forum Stock Tech
    Last Post: August 15th, 2007, 09:58 PM
  5. Civilian Plugs and Plug Wires on Military Distributor???
    By Nuke_Danarchy in forum Modified Tech Archives
    Last Post: March 19th, 2004, 12:07 AM
