Results 1 to 4 of 4
Thread: binfordm715 : Need mirror arm mount dimensions
    Port Orchard, Wash.
    Default binfordm715 : Need mirror arm mount dimensions
    Post by binfordm715 on Sept 20, 2006, 9:59am
    Those two L-shaped brackets that mount to the door to hold the mirror arm. Can someone give me a rough measurement of one?
    Thanks!
    Default thetroublemaster :
    Re: Need mirror arm mount dimensions
    Post by thetroublemaster on Sept 20, 2006, 10:12am
    Check my truck out on Saturday....
    Default texan :
    Post by texan on Sept 20, 2006, 10:13am
    The L-shaped brackets are made of 1/8" x 1-5/16" (approximately) stock. The vertical arm extends up 1-1/2" to hold the the mirror. Its end is a 1" diameter semicircle. The arm bolted to the door is 1" long. It is also radiused, but I didn't measure that; looks like a 1" radius. I may be able to post a pic tonight, if needed.
    Don
    Port Orchard, Wash.
    Post by binfordm715 on Sept 20, 2006, 10:51am
    Thanks, Don. I'm hoping to have one made up this week so I can pick them up at the PacNor FE. Your dimensions/description are just what I needed! Don't trouble yourself for a picture. I had some pics that showed it well enough. Just didn't know the dimensions is all.
    Thanks!
  1. binfordm715 : Blackout Driving Light base mount
    Last Post: November 11th, 2009, 05:48 AM
  2. binfordm715 : Soft-top mount on windshield
    Last Post: November 11th, 2009, 01:26 AM
  3. Need pic and dimensions of PTO linkage arm
    By Duane in forum Stock Tech
    Last Post: August 17th, 2008, 09:14 AM
  4. What are the dimensions of the correct Pitman Arm?
    By Binford in forum Modified Tech
    Last Post: April 4th, 2008, 08:27 PM
  5. Can someone please give me some dimensions?
    By amphi in forum Modified Tech
    Last Post: March 12th, 2008, 09:13 PM
