Results 1 to 6 of 6
Thread: bluesman2a : what are you guys using for seam-sealer?
    Atlanta, Ga.
    Default bluesman2a : what are you guys using for seam-sealer?
    Post by bluesman2a on Sept 28, 2006, 4:49am
    I finally pulled my dash tonight. Oh-my-gosh if I had known it was that easy, I would have pulled it MONTHS ago and saved having to do all that upside-down-backwards-ninja-welding...
    But the bad news is I found more rot, along the seams (sealer is GONE) and in the cowl.
    So tomorrow is get all that cleaned/patched/painted but I also want to put more seam sealer in.
    What are you guys using for seam sealer? I'm looking for something I can paint and will hold up well. Is it something I can get at a normal auto parts store (never looked before).
    Also while I'm at it, I have to replace several boogered screws from the rubber cowl, anybody have the size/specs on those?
    Thanks in advance, it's been a LOOONNNNGGGG day.
    Default porkchop :
    Re: what are you guys using for seam-sealer?
    Post by porkchop on Sept 28, 2006, 6:14am
    I bought the seam sealer that you can get from Napa. It comes in a long tube and goes in a caulking gun. Works great.
    Washington State
    Default fisherman :
    Post by fisherman on Sept 28, 2006, 8:53am
    Yep, the Napa stuff it is grey and sticky, you can tool it smooth with a damp rag and mineral spirits. It sets up pretty fast so you need to work at a steady pace. So far I have done all my body panels, and bed , under cab pretty much everywhere. Let it dry and use a primer over it otherwise the Gillespie will stay shiny for awhile where you painted over the seam sealer. It stays flexible but is also paintable.
    Default robertcowan :
    Post by robertcowan on Sept 28, 2006, 9:55am
    3M MAKES THE BEST SEALER IN MY OPINION
    Geneva, FL
    Blog Entries
    1
    Default teking :
    Post by teking on Sept 28, 2006, 10:33am
    Yep thats what I used putting mine back together...
    Default tomcat :
    Post by tomcat on Oct 2, 2006, 10:51am
    There are two sealer options from ..hmmm... i think it was 3M. One is a normal seam sealer. The other one is a combined glue and seal sealer. This one is even better. Is paintable. A friend told me they using it in his company for oltimer restaurations (jags, bentleys,..).
  1. bluesman2a : body mounts, what are you guys using?
    By bluesman2a in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 01:51 AM
  2. Speaking of seam sealer
    By Tomahawk715 in forum Open Discussion
    Last Post: June 26th, 2008, 09:33 PM
  3. Seam Sealer
    Last Post: June 23rd, 2008, 09:49 PM
  4. 11.00-16 XZL Guys: Q?
    By MarknessMonster in forum Open Discussion
    Last Post: January 21st, 2007, 01:25 PM
