  #1
Old November 29th, 2015, 04:52 PM
venominjected's Avatar
venominjected venominjected is offline
Corporal
venominjected is a Soldier
Default 1967 Kaiser Jeep M-715 6BT Build
Alright guys... time to start the build thread on this one..... heres the lowdown end goal and of parts I already have....
End goal: Somewhat stock appearing M-715 (no huge tires sorry, no spring-over axle, no crazyiness unfortunately).... Daily driven capable.... steers and stops like a modern 1-ton... with just a few too many leafs. (Hence why the m715 is known also as a 5/4 ton). Motor will stay OEM power wise... (as I have a baby 11" clutch)
1991.5 Cummins 5.9L 6BT (VE Rotary)
1993 Ford ZF S542 5 Speed Transmission
Married Ford Np205.. which will be twin sticked and also have my original m715 NP200 E-brake drum housing machined to fit the new NP205.
Ford Dana 60 HP King Pin Front Axle (1988 F350)
Ford Sterling 10.25 Rear Axle (1988 F350)
Disc brakes in all 4 corners (sterling disc conversion)
Hydroboost off of a 2010+ F250/350
Enjoy the ride!
Night I got it home off the transporter from Grand Rapids, MN...
Back to my home base in my own shop
Broken down and the hard top off and windshield hinged down
OEM Dash
Prestine bed and all the correct bumperettes and shackles
Non-numbers matching jeep tornado 230 (oem equipment)
Its replacement... 1991.5 Cummins VE
Disassemble Time
__________________
1967 M715, 6BT, ZFS542, NP205
  #2
Old November 29th, 2015, 04:53 PM
Corporal
A little more intro
Ford SBF Adapter Setup
Ford Married NP205
Ford ZF S542 Speed OD
Bare bones Part 1
Back from the steam wash bay
Time to start putting things back together
Of course... nice to sprinkle some tech in there too.... CAD of course !
__________________
  #3
Old November 29th, 2015, 04:54 PM
Corporal
A little more intro part II
Dash Concept in CAD
__________________
  #4
Old November 29th, 2015, 05:17 PM
Flingarrows's Avatar
Flingarrows Flingarrows is offline
Sergeant
Flingarrows is a Soldier
Keep it coming venom!
__________________
Thanks, George
Joshua 24:15
  #5
Old December 5th, 2015, 05:54 PM
osok osok is offline
Private
osok is a Soldier
Are you planning a cross member under the 6bt? Looking forward to your progress!
  #6
Old December 6th, 2015, 07:05 AM
Corporal
Quote:
No.... OEM frames are strong enough if your not rock bouncing them... *MOST* guys who put in 6BT's do not.... if I was upping the power from OEM (which I'm not) and had a transmission that could take it... I would indeed brace the frame underneath.
Since I'm remaining stock in my engine, and my ford ZF transmission only has an 11" clutch.... frame spreading will not be of any concern...
__________________
  #7
Old December 6th, 2015, 03:37 PM
Private
osok is a Soldier
I am also interested in your plumbing of the hydroboost to cummins PS pump and what steering box you are going with. I have a similar set up with a FSJ box that I am hoping will have enough flow to turn 39's. I am holding off on the crossmember until I notice a problem, thanks for the input.
  #8
Old December 12th, 2015, 12:01 PM
Corporal
Out with the old... in with the "new" front axle
Old 5.86 ratio closed knuckle dana 60 with drums.... in with the new King Pin, High-Pinion Ford F350 Dana 60 with discs....
The Sterling 10.25 Rear as I bought it....
Got me a Kingpin 60
Sneaking it in....
__________________
  #9
Old December 12th, 2015, 03:06 PM
md1970 md1970 is offline
Corporal
md1970 is a Soldier
why didn't you sterilize the new axle of all the old brackets and mounts before you put it inder the m715 ?
  #10
Old December 12th, 2015, 05:27 PM
Private
osok is a Soldier
drivers side front diff will make routing your exhaust easier with the 6bt.
Looking good, keep the pics coming!
1998 - 2019
Copyright 1998-2019
