The ballast resistor on a stock truck is in the ignitor housing with the coil and distributor. it is usually under the coil...follow the ires on the coil and you will find it.
The starter switch on the floor should not have any wires from the dash area. If there are, then its been modified.
The starter floor switch is wired like this:
Positive from the battery AND the charging wire, the big one, from the alternator to one side of the floor switch...starter hooks to the other side of the floor switch.
