Results 1 to 2 of 2
Thread: warwick : steering gear oil ?
    Default warwick : steering gear oil ?
    steering gear oil ?
    Post by warwick on May 25, 2006, 7:20pm
    i found the fill hole, however i couldn't figure out how to drain it.
    any thoughts or sugestions?
    manual says 1 pint and mine has been leacking, should i just top it off? and forget about draining it....then just top it off as it leaks..?
    thanks brian
    Default brute4c :
    Re: steering gear oil ?
    Post by brute4c on May 25, 2006, 10:16pm
    To drain it you have to either remove it and flip it upside down or dissasemble it....unless you want to drill and tap a drain hole and do a write up for the rest of us!!
    No good way to drain...I have that same leak...I keep topping it off...
  1. warwick : my M715 *dial-up beware*
    Last Post: November 11th, 2009, 03:49 AM
  2. warwick : diff covers ? and gear oil ?
    Last Post: November 11th, 2009, 01:53 AM
  3. warwick : LU4 winch? gear oil?
    Last Post: November 11th, 2009, 01:41 AM
  4. How do you lube the steering gear?
    By rboltz in forum Stock Tech
    Last Post: August 31st, 2009, 11:37 AM
  5. steering gear adjusting
    By george walker in forum Stock Tech
    Last Post: October 19th, 2007, 02:27 PM
