Results 1 to 2 of 2
Thread: teking : Fuel flex line duplicated
    Geneva, FL
    Blog Entries
    1
    Default teking : Fuel flex line duplicated
    Post by teking on Jun 9, 2006, 8:26am
    ... all of you probably remember from the old board that I had Classic tube duplicate the NOS flex brake lines in braided stainless. Yesterday I recieved the flex fuel line I had duplicated. Classic Tube now has COMPLETE Brake, and Fuel lines in stainless (to include the flex lines) for our M715s. If you also remember they also have the hard vent line in stainless as well.
    BTW - Jon did we lose that sticky?
    Default brute4c :
    Re: Fuel flex line duplicated
    Post by brute4c on Jun 9, 2006, 11:17am
    So far I cant find it...I was sure I had it here somewhere...might be on my backup at home...
    ok...I found this much...
    Quote:
    Re: Stainless Steel Lines
    ? Reply #3 on Yesterday at 12:03pm ? [Quote] [Modify] [Delete]
    Here's the quote I got from Mike at Classic Tube:
    1967 Kaiser-Jeep M715 Brake, Fuel, Vent, and Vacuum Line Inventory
    Brake lines: $199.00
    * Master Cylinder to Pressure Switch
    * Left Front
    * Right Front
    * Pressure Switch to Coupler on Left Frame
    * Coupler to Rear Flex Line Above Axle
    * Left & Right Rear Axle Lines
    Fuel Lines:
    * From Fuel Tank to Fuel Pump(3 pc) = $140.00
    * Fuel Pump to Carburetor = $25.00
    Vent & Vacuum Lines:
    * Distributor Vent Inlet (front of cyl head) = $12.00
    * Distributor Vent Inlet Stub (top of distributor) = $5.00
    * Distributor Vent Outlet = $20.00
    * Fuel Vent Line From Pump to Air Cleaner = $15.00
    * Bellhousing Vent Line = $20.00
    * Front Axle Vent Line = $25.00
    * Rear Axle Vent Line = $8.00
    * Long Vacuum Inlet (to left cyl head) = $20.00
    * Vacuum Inlet Elbow at Pump = $8.00
    * Vacuum Outlet Elbow at Pump (to wipers) = $8.00
    * Bellhousing Tee to Transfer Case Vent Hose = $5.00
    All Lines Are Stainless Steel With Stainless Fittings
  1. Engine Compartment Flexable fuel Line (Fuel Hose)
    By BlessedM715 in forum Stock Tech
    Last Post: January 3rd, 2010, 01:47 PM
  2. Parts? Fuel line and plug wire wrench?
    By JDS in forum Stock Tech
    Last Post: June 16th, 2009, 05:17 PM
  3. possible Holley carb return fuel line
    By pavel3 in forum Stock Tech
    Last Post: July 20th, 2008, 05:53 PM
  4. Less springs more flex
    By 5quarter in forum Modified Tech
    Last Post: May 31st, 2008, 08:43 AM
  5. Hard Fuel Line Size?
    By fng in forum Modified Tech
    Last Post: August 24th, 2007, 11:06 AM
