Results 1 to 6 of 6
Thread: grantshire : Is a 1990 14 bolt a good axle?
    Default grantshire : Is a 1990 14 bolt a good axle?
    Post by grantshire on Jun 21, 2006, 2:49pm
    I found a 1990 Suburban14 bolt for $100. Gears are wrong and it will need to be converted to disk brakes. Most info I have found on disk brakes cover earlier axles. Should I buy this one or look for an earlier/older 14 bolt?
    Default tacomainoh :
    Re: Is a 1990 14 bolt a good axle?
    Post by tacomainoh on Jun 21, 2006, 2:54pm
    if it's a full-floater, you're golden. If it's not, and coming out of a Suburban I suspect it's not, then I'd pass. I have a Suburban w/the semifloater 14bolt, and while it's a decent axle, it's not quite as heavy duty as the full floater.
    You should have no trouble finding the full floater in earlier trucks, every 3/4t , pre88 GM truck I've seen has had one.
    Default elwenil :
    Post by elwenil on Jun 21, 2006, 2:55pm
    I'm not sure on that particular axle but you do need to watch for the semi-floating axles. The 14 bolt can be had in the light duty semi floating design (which I think has a smaller ring gear diameter) and the more heavy duty full floating 14 bolt. $100 is a really good deal on a full floating 14 bolt, but not such a good deal if it's the more worthless semi floating design.
    EDIT: d**n, Tac, you beat me to it, but yeah, ditto.
    Post by grantshire on Jun 21, 2006, 4:22pm
    Thanks for the info/help. I just found a 74 FF 14 bolt in a C30 1 ton bread truck. Don't know the axle ratio but for $50 bucks, I don't care! I have to pull it myself but I can have the springs, plates & rear driveshaft for free! The guy even has a backhoe to lift the van up and load it on my trailer.
    Guess what I will be doing Friday evening?
    Default brute4c :
    Post by brute4c on Jun 21, 2006, 4:33pm
    Hitting the bars early? Pry bars that is!!
    Post by tacomainoh on Jun 21, 2006, 7:36pm
    Good score! Around here 14 bolts are between free and about $150, depending on condition and location LOL
  1. Stupid axle/bolt pattern question/idea
    By 2ndA in forum Modified Tech
    Last Post: February 10th, 2010, 01:32 PM
  2. grantshire : 70" WMS/WMS 14 Bolt Questions
    Last Post: December 15th, 2009, 08:04 PM
  3. Rear axle u-bolt size
    By Jester in forum Stock Tech
    Last Post: October 30th, 2008, 04:48 PM
  4. 14 Bolt FF Rear Axle Swap
    By BigBlockBurris in forum Modified Tech
    Last Post: January 13th, 2008, 09:54 AM
