  #11
Old July 18th, 2020, 03:41 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Those bolts LOVE to back out...teflon thread sealer is a MUST!!
  #12
Old July 18th, 2020, 06:09 PM
onemanarmy onemanarmy is offline
Civilian
onemanarmy is a Soldier
I can't say for sure....but i think I'm missing those bolts.
Any clue of size/thread?
Thanks for the info on all of it.
  #13
Old July 28th, 2020, 08:17 AM
Civilian
I've got another cross member running behind the transmission, so I can't see where those 2 bolts go.
Is that extra crossmember a stock piece?
It's bolted, I can remove it....but is it stock?
  #14
Old July 28th, 2020, 10:11 AM
m38inmaine's Avatar
m38inmaine m38inmaine is offline
m38inmaine is a Soldier
There is a cross member directly behind the transmission, should be a shelf welded on it to mount the back of the transmission on, it has a large round hole in it on the RH side for the front driveshaft to pass through. I looked at mine quickly and if I recall it's bolted in.
  #15
Old July 28th, 2020, 10:40 AM
eightydeuce's Avatar
eightydeuce eightydeuce is offline
eightydeuce is a Soldier
Definitely bolted in, I had to remove mine to repair the frame in that area.
Ah the memories...
  #16
Old July 29th, 2020, 06:17 AM
Civilian
Yea, mine is bolted in. I'll take it off and check the back of my trans for those missing bolts.
