Results 1 to 3 of 3
Thread: Disc Brakes Arrived!!!! (Part II)
    Northern Colorado
    Default Disc Brakes Arrived!!!! (Part II)
    I tried to dig up the old thread, for continuity, but I couldn't find it. I dove back into the brakes today.
    The short version: Use a double diaphragm booster with large bore master cylinders
    The long version: Thinking that my brake booster was bad, I swapped it out and installed a double diaphragm booster in its place. Wow. Instant brakes! The truck stops without the pedal going all the way to the floor and it even stops when in low range. I think that as the pads get broken in, they will grab even more. I'm happy. Definitely money well spent. It doesn't stop as quickly as my FSJ, but it's also heavier, too. It'll be nice not having to give my leg a workout every time I drive the thing!
    Springdale, Arkansas
    Okay, dumb question #2011. If I use the recomended '72 Vette MC with brand new replacement brake lines, can I just put a booster behind it, mod the shaft for the actuator and have boosted brakes? I have a brake booster from a FSJ in the garage but it is currently hooked to a drum/disc M/C If it'll work my plan is to rob it off the back and put it on the Vette M/C.
    Works? Wont work? Ideas, comments?
    Winlock, WA
    Good to hear that they are working good and you are liking the results.
    Btw, here is a link to your first post.
    You should be able to look at your public profile and sort through the threads that you started to find stuff like this.
  1. disc brakes?
    Last Post: July 27th, 2007, 03:48 PM
  2. Disc Brakes Arrived!!!!
    By FSJGuy in forum Modified Tech
    Last Post: May 22nd, 2007, 09:56 AM
  3. F-450 disc brakes and 8lug conversion
    By Willie_715 in forum Modified Tech
    Last Post: March 14th, 2007, 03:22 PM
  4. Dana 70 Disc brakes 8x6.5"
    By tngreenmachine in forum Modified Tech
    Last Post: February 21st, 2007, 04:34 PM
  5. Looking to get disc brakes
    By 40Grit in forum Modified Tech Archives
    Last Post: May 13th, 2004, 01:42 PM
