Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Front knuckle housing
  1. #21
    It is crazy...basically I just gave a "dont do this to your truck" warning there...I think it was actually Barrman who bought the axle and did the autopsy on it....I could be wrong on that part but I know it was a highly respected mechanical member like him.
  2. #22
    Jun 2009
    Mt. Prospect, Illinois 60056
    Well Jon, this has been an informative post I think. Hopefully everyone got the message, to not pack your front knuckle housings with grease. Everything in moderation. More is not better in this case.
  3. #23
    Ill tell ya, I am so thankful for this forum. When doing a routine lube maintance, I saw the fill/drain plugs at the knuckle. I figured because of where they were, that you would just put a gear oil and be done. I even had the bucket sitting beside the wheel ready to go. Then I thought, I better look this up on the forum. I put heavy duty gear grease in. Next time, I will go with the pudding. I think I might make a special grease gun, just for it. (pulled the end nipple on gun, for faster fill. Yes, my hands are tired)
  4. #24
    Get the John Deere corn head grease. Fits right into your grease gun.
  5. #25
    Just to confirm (or refute) a hunch; the grease in the knuckle is really only for lubing the king pins, right? My '08 Dodge has its front axle shaft u-joints sitting in right out in the open. I wouldn't think they're different in their construction from an M715 u-joint, so no actual lubrication of the u-joint can take place due to the bearing seals, even if they're surrounded by nutritious, delicious cornhead grease.
    Am I on the right track here?
  6. #26
    Quote Originally Posted by Nailhead View Post
    The u-joints inside of the steering knuckles shouldn't have any seals on them allowing lubricant to seep into the needles.
    I use 140w gear oil in all of my 1960's jeep steering knuckles.
    I also keep the hubs locked in on them to keep the gear oil slinging around.
  7. #27
    Look into 00 grease sold at tractor supply. We use it in hay mowers and hay rake gear boxes. Like a thin grease or heavy oil
    https://www.tractorsupply.com/tsc/pr...ndle-grease-00
  8. #28
    Quote Originally Posted by jeepdan View Post
    Thanks Dan-- I haven't been in there yet, so I'm not yet familiar with those knuckles.
    I don't yet know what exactly I'll put in there, but those hubs will stay unlocked until I need them, maybe lock 'em once in a while to keep things lubed. Not enough oxygen around here to burden the 230 with unnecessary frictional loads.
  9. #29
    That is a good plan as long as you do lock them in sometimes to lube the upper king pin bearing...otherwise...bad things happen...
