Results 1 to 8 of 8
Thread: fisherman : 200 ebrake housing on np202
    Washington State
    Default fisherman : 200 ebrake housing on np202
    Post by fisherman on Oct 14, 2006, 11:15am
    Someone posted this was a bolt on conversion, Maybe on theirs, but not on mine. What i found was the rear output or bearing cover from the 202 was removed and I put the 200 ebrake housing on, not enough room for bearing clearance. The bolt patterns are the same, but bearings are different. My 200 uses cone shaped roller bearings on the rear that look like they set into a race. The rear output on the 202 uses a larger roller type bearing that sits into the rear opening in the transfer case and has a clip around it to hold it there. This sticks out by 3/16", therefore the 200 brake housing will not go on without modifications. I was going to try to chock up the 200 housing and turn in a lathe to step down inside for the bearing clearance. I decided to make a spacer out of 3/16" flat stock instead. I used washers and mocked it up last night and it appears I have just enough left to get the nut on the shaft and insert cotter pin. A fellow member made me an adapter setup for the centered rear output of our 200. That and the ebrake setup will be installed on my 202, then on to new bearings and seals. I will post some pictures as soon as I finish the spacer, that is today's project. Just for you to know there are two ways that I can see to make this work. Incase anyone else wants to run a 202 divorced case. I found this one in a 1970 International 1100. Any one need a good running 345? Fisherman
    Default brute4c :
    Re: 200 ebrake housing on np202
    Post by brute4c on Oct 14, 2006, 7:53pm
    Thanks for posting this...there isnt alot of info on the 202...I would never have known either way if it would work or not without your info.
    Washington State
    Default fisherman :
    Post by fisherman on Oct 15, 2006, 12:23am
    Anyone know if there are any differences between the 202 and the 205 transfer cases, other than looks, ratio? The 202 looks pretty similiar to the 200.
    Default robertcowan :
    Post by robertcowan on Oct 15, 2006, 11:19am
    I TOLD YOU THERE WAS MACHINING THAT HAD TO BE DONE. REMEMBER MY POST ( ALL ALL MACHINE WORK INCLUDED IN MY KIT ) SAME WITH THE NP205 INSTALL. THE HIGH ANGLE DRIVE FLANGE ALSO NEED TO BE MODIFIED FOR THE BRAKE DRUM .......
    Default brute4c :
    Post by brute4c on Oct 15, 2006, 3:26pm
    The NP200 and NP205 are pretty much rated the same...though the NP205 is the newer better version of the NP200....the NP202 is rated higher than either of the others...it is physically bigger by a bit as well...and it is rarer...
    Washington State
    Default fisherman :
    Post by fisherman on Oct 15, 2006, 7:33pm
    I didn't know you had a kit Bob, I started my machining today, will finish next weekend as the lathe is at my friends house. I'll be to busy with work this week. I'll post up pics when finished.
    Post by robertcowan on Oct 15, 2006, 9:05pm
    KEEP TOLERENCES TIGHT TODD
    Post by robertcowan on Oct 15, 2006, 9:06pm
    ALL MY NP202,S CAME OUT OF 1 1/2 TON TRUCKS. THERE ALOT MORE H/D THAN THE NP205,S AND THEY ALL CAME WITH 1410 YOKES
  1. fisherman : Np 200 ebrake mounting on to np 202
    By fisherman in forum PseudoZone - Mod Tech Archive
    Last Post: December 15th, 2009, 08:03 PM
  2. robertcowan : differential housing spreader
    Last Post: November 11th, 2009, 05:40 AM
  3. Complete pic set of ebrake
    By fng in forum Modified Tech
    Last Post: April 20th, 2007, 11:45 PM
  4. Pictures of my ebrake
    Last Post: April 13th, 2007, 12:39 AM
  5. 200 ebrake housing on np202
    Last Post: April 8th, 2007, 08:48 PM
