Results 1 to 4 of 4
Thread: snuffy : Sump...
    Auburn, AL
    Default snuffy : Sump...
    Sump...
    Post by snuffy on Oct 18, 2006, 1:04pm
    Again, I must draw on the collective wisdom of Zoners...
    Repowering with a 6.9L diesel. Do I want to get a front or rear sump??? I recall there being some problem with this with another engine, but that was many moons ago on the old site.
    Thanks,
    Snuffy
    Atlanta, Ga.
    Default bluesman2a :
    Re: Sump...
    Post by bluesman2a on Oct 18, 2006, 1:55pm
    Not sure on the 6.9, but the engine that was originally in my truck (351C) had a front sump. It hit the front axle in it's service.
    Unless there is a driveshaft clearance issue, then I would go with rear sump.
    Default barrman :
    Re: Sump...
    Post by barrman on Oct 18, 2006, 2:09pm
    All the Chevy engines are rear sump if that helps any. Along with the stock 230.
    Default brute4c :
    Re: Sump...
    Post by brute4c on Oct 18, 2006, 3:10pm
    Rear sump is needed to avoid slapping the differential.
  1. snuffy : CCAs
    By Snuffy in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 04:22 AM
  2. snuffy : Seat replacement recommendations???
    Last Post: November 12th, 2009, 03:47 AM
  3. snuffy : Found for the 12 volters....
    Last Post: November 11th, 2009, 05:42 AM
  4. snuffy : Frame Paint?
    Last Post: November 11th, 2009, 04:50 AM
  5. snuffy : Heat'n and Beat'n
    Last Post: November 11th, 2009, 02:49 AM
