Old July 9th, 2007, 07:19 PM
fng's Avatar
fng fng is offline
Sergeant
fng is a Soldier
Default Weather stripping
Got some proper shaped rubber weather stripping about 6 months ago on ebay. Just pulled it out and while sizing it up for install I noticed a few hundred holes in the door around the area where the stripping goes.
My qwerstion is what have y'all used to secure the strip with? Should I use glue or some small screws with big washers? I think the original had some kind of embedded spring like clips that went into the holes but not sure.
Any advice is good advice at this point.
joesco715 : Stripping vs Blasting and other ?'s PseudoZone PseudoZone - Open Archive 14 November 13th, 2009 11:54 AM
Door weather stripping fisherman Modified Tech 2 July 24th, 2007 11:36 AM
A little cold weather help?? Snuffy Modified Tech 3 April 17th, 2007 04:42 PM
Rubber Weather Stripping source Gregg Irvin Open Discussion 4 March 5th, 2007 06:07 AM
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
1998 - 2021
Copyright 1998-2021
