Page 6 of 15 FirstFirst 123456789101112131415 LastLast
Results 51 to 60 of 145
Thread: Canadian Project M715... Eh!
  1. #51
    More progress. Front springs have been moved under the frame to match up with the D60 kingpin perches. I didn’t like the shackle angle on the rear after the shackle flip so I carefully drilled out the rivets and welds and moved the shackle mounts forward. Front axle is ready to mount as soon as the paint dries!
    I got all new glass and seals. My black vinyl stars showed up.
    I got rid of the 37 x 12.5” tires and have 40” x 13.5 on the way. I was going to use my old H2 rims but after a few hours grinding and smoothing corroded chrome enough to get some OD green on them I decided it wasn’t going to look good and ordered some beefy steel rims instead. They’re satin black and I haven’t decided if I’m going to leave them or shoot them in OD green...
    I also decided to LS swap my 83 Camaro. That means the healthy 350 in it gets a new home between the frame rails of the M715. Should save lots of time on the M715 build over rebuilding the old 350 I had for it. All I need to do is swap the headers out for some centre dump manifolds I have and switch the Holley 700 DP to an Edelbrock 4 barrel with electric choke that I just got.
    Next up, frame paint and getting the rear axle buttoned up!
  2. #52
    Apr 2016
    Katy, TX
    I am very jealous. Nice welds. What kind of welder are you using for frame work?
  3. #53
    Quote Originally Posted by jhartings View Post
    Thanks! I’m no great welder, but the new MIG machines make anyone look like they know what they’re doing, lol. It’s a little Miller 211 dual voltage. The duty cycle isn’t super high so I get lots of 10min breaks waiting for the thermal protection when I have it up closer to max for 1/4” steel, but it’s been great for most stuff I do in the 1/8” to 3/16” range. It does .040” - .060” pretty good too for bodywork. I usually have it plugged into 240, but it’s nice that I can run it off my generator on 120 for quick fixes nowhere near an outlet!
  4. #54
    Those digital gauges are great
  5. #55
    Where can i get a set of these electronic gauges but i need one with mph not kph thanks alot
  6. #56
    Quote Originally Posted by randall555 View Post
    https://www.intellitronix.com/produc...rsal-gauge-kit
  7. #57
    Default Eletronic gauges
    I got it thanks alot !
  8. #58
    Well, the kids have hockey 14 times per week, but still plugging away! Should be a productive Xmas break. 95% of the parts are here and ready to assemble!
  9. #59
    Feb 2007
    Bloomfield CT
    Looking Good!
    Is that real money?
  10. #60
    Apr 2016
    Katy, TX
    Talking
    Real nice! Like the rims/tires. What paint did you use for the frame? I am about to paint mine and will probably end up with POR15.
