Results 1 to 3 of 3
Thread: Mirror Arms
    Washington State
    Default Mirror Arms
    Can someone please give me the measurements for the mirror arms. I believe drivers side is shorter, passenger longer. If you could also give me the measurements for the lower part of the mirror arms. The bottom part, the top part sleeves into. Just want to make sure everything is good to go before I paint and bolt everything up. I think my mirror arms are off something else, not M truck. I will cut them if I need to. Thanks everyone.
    Port Orchard, Wash.
    I'll get them for you in the morning.
    Just as with your "OEM" arms, the stock ones can adjust for length. The two I got (off Mike's truck those axles you have came from) are the same, as I recall. I'll measure in the morning and let you know for sure though. But yes, the stock ones are shorter than what you have, so you'll do some cutting if you want to go for the stock look.
    -- Tim Taylor
    Port Orchard, Wash.
    Not quite morning, but here it is....
    The lower half measures about 5-5/8" from the center of the lower mounting bolt hole to the top of the collar.
    The upper half measures about 5-1/4" from the bottom of it to the center of the mirror head mount.
    Both driver and passenger arms were the same dimensions.
    -- Tim Taylor
  1. Mirror options
    Last Post: September 20th, 2008, 06:06 PM
  2. mirror bracket for my 715
    By 0369ssgtusmc in forum Stock Tech
    Last Post: February 24th, 2008, 06:07 AM
  3. Sideview Mirror Mounts
    By joesco715 in forum Open Discussion
    Last Post: January 21st, 2007, 07:51 PM
  4. Mirror pics?
    By gonz in forum Stock Tech Archives
    Last Post: March 2nd, 2004, 11:10 AM
