Results 1 to 3 of 3
Thread: rear drive shaft
    Default rear drive shaft
    need a little help, does it go to the off set ,it looks like that's for the pto side or straight back. want to get a drive shaft made.
    With a stock NP200 in there it will (in stock trim) go from the pass side output of the t-case to the rear axle.
    Unless you've messed with the drivetrain location, you might be well served by picking up a used take off shaft. I've got one in decent shape. I'm willing to be others here do as well.
    Jason
    Stock, the driveshaft runs from the passenger side yoke of the tcase...man have swapped it to the drivers side yoke to eliminate the very prominent whine of the stock case.
  1. Relocatuion of Drive Shaft
    By Pen1311 in forum Modified Tech
    Last Post: March 22nd, 2010, 10:25 PM
  2. fasteddie : Drive shaft vibration
    Last Post: November 11th, 2009, 11:26 PM
  3. Winch Drive shaft
    By bradley in forum Stock Tech
    Last Post: October 5th, 2009, 08:19 PM
  4. front drive shaft
    By Overfiend in forum Stock Tech
    Last Post: December 26th, 2008, 11:59 PM
  5. Drive shaft/gas tank clearance?
    By boghog in forum Modified Tech
    Last Post: October 2nd, 2007, 08:51 AM
