Results 1 to 4 of 4
Thread: jfnemt1ff1 : Timing
    Default jfnemt1ff1 : Timing
    Timing
    Post by jfnemt1ff1 on Jun 13, 2006, 6:44am
    HI everyone I have a question, Setting the timing on M725 the books say set at 5deg BTDC,Now the question with or without vac adv. hooked up .
    John
    Default rpgdeity :
    Re: Timing
    Post by rpgdeity on Jun 13, 2006, 2:28pm
    Without the advance hooked up.
    Re: Timing
    Post by jfnemt1ff1 on Jun 13, 2006, 3:20pm
    Thanks for the help.
    Default brute4c :
    Re: Timing
    Post by brute4c on Jun 20, 2006, 9:38am
    If you mean on the stock military waterproof igniter setup, there is no vacuum advance to worry about disconnecting...
    If you have a civilian ignition with the vacuum advance....or any ignition with one for that matter, ALWAYS disconnect the advance unit to set the initial timing...the vacuum advance is on top of that initial, not part of it.
  1. jfnemt1ff1 : Wiper blades
    Last Post: November 12th, 2009, 04:43 AM
  2. jfnemt1ff1 : ablinn
    Last Post: November 11th, 2009, 05:49 AM
  3. m-715 timing set
    By phcarr in forum Stock Tech
    Last Post: September 25th, 2007, 04:38 PM
  4. 350 timing
    By bumnog in forum Modified Tech Archives
    Last Post: January 9th, 2004, 10:45 AM
