Old January 5th, 2004, 01:22 PM
Private 1st Class
Default stock transfer case shifters wanted
I just talked to a guy at Chuck's Trucks in Florida and he told me that the knuckles can be swapped from side to side to put the tie rod in the front, or the rear can be completely swung around but that will change the pumpkin location if it's and uncentered/un-narrowed axle. FYI, when they center or narrow one of the REO front axles they cut around 7" out of the driver's side housing, weld it back together and use then install a passenger side axleshaft in the driver's side.
Big Blocks RULE!
Old January 5th, 2004, 02:56 PM
Nuke_M1028 Nuke_M1028 is offline
Nuke_M1028 is an Observer
Spicer, I have a front rear in the rear. Turned around backwards. With the center chunk turned 180 degrees. Oh I am so confused, But it works. M1028
Old January 11th, 2004, 05:35 PM
Nuke_johnsummers Nuke_johnsummers is offline
Civilian
Nuke_johnsummers is an Observer
if you want to use a front for a rear steer go strait back with it i didn't turn the chunk because the gas tank wouldn't clear the drive shaft if you do like M1028 said and turn the whole axle around it will offset the shaft but the diff plates would be running in different paths
Old January 12th, 2004, 08:04 PM
Civilian
o you can narrow them 10'' buy flipping the hubs around but it has to be machined 250 th not a big deal cheeper than buying another short axle and probaly safer than cutting and rewelding the tube :!:
it\'s not how big the engine is ,it\'s how hard you push the skinny pedal
Old January 13th, 2004, 05:39 AM
Private 1st Class
Hey John...maybe you can explain something to me to tell me that I'm out to lunch. Why not keep the axle full width and get deeper back spaced wheels? Doesn't that allow the tire to have a much smaller or a lot less 'swing' to it as it would be turning more on a centrally located point not way to one side?
Big Blocks RULE!
  #6
Old January 14th, 2004, 05:22 PM
Civilian
yes that is what i did
  #7
Old January 15th, 2004, 06:51 AM
Private 1st Class
Hey John, I got to looking at a front rockwell I have and decide that I can leave it with the tierod in the rear. I'm thinking I can fab a heavy (like 3/4"-1" thick) arm that will bolt to the top of the passenger side knuckle. That *should* clear the springs, allow a simple link for the steer box, and (as you had mentioned) keep the tie rod out of harms way. I bought some disk brake hardware that isn't supposed to work together that I'm going to see what I can do with...
Big Blocks RULE!
  #8
Old January 17th, 2004, 08:33 AM
Civilian
Default NP 205 Low Range Info
i dont think it will work i think i tried that
  #9
Old January 19th, 2004, 06:28 AM
Private 1st Class
I think I got the steering under control now. I found that because of the size of the knuckle the wheel can only be offset so far so I may just flip the hubs. I saw where the interference would be between the spindle studs and the hub.
Big Blocks RULE!
HTML code is On
Yet another rockwell question rustwagon Modified Tech 6 January 14th, 2009 06:30 PM
rockwell help... foodstamp Modified Tech 10 December 26th, 2007 06:30 AM
