Results 1 to 3 of 3
Thread: Loose spindle bolts
    Default Loose spindle bolts
    The lockout hub problem I'm having was a secondary find to the original problem that I set out to fix. I don't imagine that this happens to anyone but me, so...
    I heard what sounded like loose wheel bearings up front one evening, so I carefully took the truck home. When I got the wheel and drum off, I found that it wasn't the bearings at all! The spindle bolts were loose! All of them still locked in place by the tabs that are supposed to hold them, but still loose. I would say they needed anywhere from a quarter turn to more than a full turn to get them torqued. Same on the other side but not as loose. It was a good time to re-pack and adjust the bearings, but still! Has anyone had this happen to them?
    1968 M-715 w/1100R16s on Stockton wheels, H3 headlights, 2bbl upgrade...
    New Haven, CT
    Quote Originally Posted by TJinSD View Post
    Once to me. And I've seen it happen another time.
    Quote Originally Posted by Mikel View Post
    Yikes. So how do they get loose if they are still tabbed in place?
