Results 1 to 6 of 6
Thread: bluesman2a : Door Tech...
    Atlanta, Ga.
    Default bluesman2a : Door Tech...
    Door Tech...
    Post by bluesman2a on Oct 9, 2006, 3:08pm
    OK, so I want to start reconditioning my doors and I need a little help here.
    Some questions:
    1) I have the external "wipes" for the outside seals, what are the INSIDE tabs called?
    2) Can I use civvie/FSJ parts for this? If so what parts are common?
    3) The "track/slots" on the windows, I THINK should have felt in them, where can I get replacements? The window/glass is loose and rattles badly.
    4) Are there any other seals/felt/track/"consumable" parts I should consider replacing and if so where should I look for them?
    Regards,
    Herb
    Default brute4c :
    Re: Door Tech...
    Post by brute4c on Oct 9, 2006, 4:05pm
    In this image:
    #5 is called "WEATHERSTRIP, DOOR, LOWER"
    FSN: 5680-411-5700
    Reference number: 11657805
    FYI, the #2 item is called either " WEATHERSTRIP, DOOR, OUTER, LEFT" or WEATHERSTRIP, DOOR, OUTER, RIGHT, thus indicating the outside one has a left and right side piece but the inner one does not....heres the total info for those 2 pieces if anyone needs it:
    FSN: 5330-157-6190
    11640932-2
    FSN: 5330-157-6187
    Reference number: 11640932-1
    Item #1 is:
    KIT, WEATHERSTRIP, DOOR BELT OUTER
    FSN: 2540-933-3540
    Reference Number: 5704439
    #4 is:
    CHANNEL ASSEMBLY, FRONT WINDOW, L. H.
    FSN: 2540-476-5498
    Reference number: 11640984-1
    CHANNEL ASSEMBLY, FRONT WINDOW, R. H.
    NO FSN GIVEN
    Reference number: 11640984-2
    There is also 1 weatherstrip on the window that rolls up and down...in this pic, #4, as well as 2 seals between the glass and the frame, #2 and #5:
    #4 is: WEATHERSTRIP, WINDOW GUIDE RAIL
    NO FSN GIVEN
    Reference number: 11657763
    #2 is: SEAL, FRONT WINDOW
    FSN: 9390-136-9204
    Reference number: 11657751
    #5 is: SEAL, LIFT CHANNEL
    NO FSN GIVEN
    Reference number: 11657761
    There should be felt type stuff in the channels...dont know off hand who would have it...the usual sources like Memphis Equipment maybe...
    Geneva, FL
    Blog Entries
    1
    Default teking :
    Re: Door Tech...
    Post by teking on Oct 9, 2006, 6:56pm
    Some questions:
    Regards,
    Herb
    here ya go brand new and refurbished!! felt window channels. Windows are so tight now i had to work them for a few days to get them to loosen up after the new felt.
    this place can do almost anything. i use them ... http://restorationspecialties.com/ Send your old parts to them and they will restore and/or create new ones. I got all my door wipes inside and outside and channel felt done there.
    I got the following at either VPW or Memphis equipment.
    #4 is:
    FSN: 2540-476-5498
    NO FSN GIVEN
    Northern Colorado
    Default fsjguy :
    Re: Door Tech...
    Post by fsjguy on Oct 9, 2006, 7:55pm
    I installed civilian doors on my 715. See me website for the writeup.
    Oops. I thought it was in my sig file. It's www.bigscaryjeep.com
    Default barrman :
    Re: Door Tech...
    Post by barrman on Oct 10, 2006, 3:36pm
    I have removed my doors about 6 times in the last few months. One tip I figured out is to put PVC pipe insulation on the front edge of the door so you don't scratch your fenders while worknig the hinges out of their slots once you unbolt them.
    Default xjchief :
    Re: Door Tech...
    Post by xjchief on Oct 10, 2006, 5:23pm
    Some day I'm going to have to drive down and take a look at your truck Teking. From the pics you've posted it looks like you've done an excellent job of restoring it.
  1. gaskets under door handles, door panel clips, widow clip
    By Mudkaiser in forum Modified Tech
    Last Post: February 17th, 2024, 10:33 PM
  2. bluesman2a : Speedo Recommendation.
    By bluesman2a in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 03:12 AM
  3. bluesman2a : Doubler X-Member
    Last Post: November 11th, 2009, 03:05 AM
  4. bluesman2a : New Lines...
    Last Post: November 11th, 2009, 03:03 AM
  5. A bit of stock tech and modified tech
    By jeepfan93 in forum Modified Tech
    Last Post: January 8th, 2007, 09:58 AM
