Originally Posted by
moosejr
Bushytails, . .A power brake unit off of a 70's-80's FSJ, pickup or cherokee is an easy install, you get both power brakes and a dual master cylinder, have to do minor work on the brake lines, drill a couple holes in the firewall, and modify the pushrod for the booster, .. .I did the whole thing in about 3 hours. . .
With a stock 230 though, you have a clearance issue with the air cleaner if you add a booster on the firewall. Probably why the Hydro-Vacs were popular.
