Results 1 to 4 of 4
Thread: binfordm715 : Speedo cable lube
    Port Orchard, Wash.
    Default binfordm715 : Speedo cable lube
    Speedo cable lube
    Post by binfordm715 on Aug 18, 2006, 2:23pm
    What's the right lube to use for the speedometer cable? Light machine oil, or is there something that would work better?
    Default tacomainoh :
    Re: Speedo cable lube
    Post by tacomainoh on Aug 18, 2006, 2:24pm
    I would say that ought to do the trick, if you need any at all.
    Default thetroublemaster :
    Post by thetroublemaster on Aug 18, 2006, 2:28pm
    When I had my cj calibrated for a competition the tech dude said vaseline was the shizzle for speedo cables. I would imagine light oil or anything relatively thin would work fine.
    Default robertcowan :
    Post by robertcowan on Aug 18, 2006, 4:53pm
    for over 25 years i used white lithium grease you buy in the auto parts places, pull out the brass inside cable, put the tubeof grease in the outside housing of the cable and squeeze all you can inside the cable then take the inside cable and lube it up good about 6" at a time and push it back insde the outer cable housing, keep doin this till its all back inside. it will be good for about 10 yrs or 100,000 miles. best way to tell if your cable needs lube is your speedo or tach pointer will bounce.
    bob
  1. oddave715 : Speedo Cable Install
    Last Post: November 12th, 2009, 02:34 AM
  2. binfordm715 : Hand throttle cable installation query
    Last Post: November 12th, 2009, 12:26 AM
  3. Speedo Cable
    By Chop Parlor in forum Stock Tech
    Last Post: October 14th, 2008, 10:03 AM
