Results 1 to 3 of 3
Thread: For the want of a clip?
    Default For the want of a clip?
    Am mounting the accelerator cable, but am missing the clip that holds the cab side of the cable flush with the firewall. Is this an off-the-shelf item, I've never seen anything like it. Can I use a C-clip in it's place? Or do I have to order from Memphis again?
    KINGSPORT, TN.
    better do it right or it will let you down. do it right once and be done with it.
    bob
    Order the clip. Mine was missing and I tried about 5 different "replacements" that looked like they would work. Non did for more than a week or so.
    The only option I didn't try, but think would work great is this. Remove the cable, figure out the OD of the end where the clip goes, run a die over it to put threads on the outside, get a nut that will screw on and then just bolt the thing down.
  1. front clip removal
    By chadriley5 in forum Open Discussion
    Last Post: January 2nd, 2010, 07:52 PM
  2. rpgdeity : Door regulator clip?
    Last Post: November 11th, 2009, 01:47 AM
  3. Throttle cable clip
    Last Post: March 2nd, 2008, 06:16 PM
  4. Front Grill / Clip Removed
    By joesco715 in forum Open Discussion
    Last Post: January 11th, 2007, 05:25 AM
  5. Window control arm clip
    By brute4c in forum Stock Tech Archives
    Last Post: May 16th, 2004, 04:10 PM
