Old January 20th, 2014, 03:04 PM
KaiserM715 KaiserM715 is offline
KaiserM715 is a Soldier
Default M715 Hauler / Crawler Build
I picked up a 68' M715 that’s lived most of its life in Chico, Ca. I have been driving past this thing for the last 10 years and finally decided to stop by and see if it was for sale. Long story short … I brought her home. I am trying to stick with the 1 ton hauler / crawler theme and keep it pretty junk yard / budget friendly. It's pretty much rust free so I don’t plan on doing any body work.
Build plans are as follows (subject to change at any time):
454 BBC
SM465
NP205
CUCV Dana 60 SOA
Undecided on rear axle (14 bolt, Dana 60, Dana 70)
Hydro assist steering
40 x 13.5 x 17 (Goodyear MTRs, Toyo MTs, BFG KM2s)
Roll cage
And a bunch of other stuff
Towing
Resting Place
Bought this with a bunch of related parts
Rebuilt outers
Tear down
Stock leaf springs over axle mockup
Mockup 1
Mockup 2
Old January 20th, 2014, 03:06 PM
More pics
Flex
Swing Shackle Frame Eye
Front Spring Hanger 1
Front Spring Hanger 2
Front Spring Hanger 3
Old January 20th, 2014, 04:09 PM
More more more !!!!
454 BBC has been rebuilt twice so its .060" over now. It was pulled from a welding truck 15 years ago just after a fresh rebuild because it wasn't running well. I just pulled the valve cover to find the lock nut on the rocker arm had backed off and the rocker popped off the push rod for an intake valve. Hopefully that’s it. We'll see as I get further into it.
Block
Block 2
Clutch and Flywheel
Peanut port heads
Aluminum Intake and 600 cfm Holley carb
Old January 20th, 2014, 05:36 PM
fishtail's Avatar
fishtail fishtail is offline
Sergeant
fishtail is a Soldier
Nice build so far. Keep the pics coming.
BTW, here's your truck at the GSA auction:
[IMG][/IMG]
Scott
Old January 20th, 2014, 07:42 PM
Troop ISP's Avatar
Troop ISP Troop ISP is offline
Corporal
Troop ISP is a Soldier
Truck looks great. Did you put the new differential cover and high steer on the axle or did you buy it that way? What gearing will you run?
The shackle flip and front spring mounts look very similar to what I did. Rather than use the stock springs I used 2inch lift 3/4 ton Chevy lsprings for a little more flex. Did you pull a couple of the leaves out of the stock spring pack?
Keep us posted on the build.
Scott, you amaze me how you find this stuff!
  #6
Old January 21st, 2014, 04:57 AM
ray steadward ray steadward is offline
Private 1st Class
ray steadward is a Soldier
Nice!.....Wish we had anything rust free out here....
Is that real money?
  #7
Old January 21st, 2014, 09:57 AM
Scott,
Thanks for the picture, pretty recognizable with a gallon of white paint splattered across the front.
Troop,
All the extras were part of a package deal with the axle: CUCV Dana 60, Spartan Locker, new calipers, new brake pads, 2x TRE's and 2x drag link ends w/ tube adapters, WFO high steer kit, Ruff Stuff Diff cover, DOM Tubing, ubolts, spring plates and hardware, wheels and tires (rollers).
I should have elaborated a little more… I tried to reuse the stock leaf packs with 2 leaves pulled but it still sat too high for my liking. I almost copied your front hanger design but I don’t have a great way of drilling accurate holes in my garage. So I opted for the 4x4 tube and WFO universal spring hangers. I got a set of Dodge W350 leaf springs at the Pick and Pull. They are just about flat at ride height and the rear spring eye is flipped to the bottom side of the leaf pack. This gives some more clearance to the frame, lets me sit lower and keep 4-6 ° of caster.
  #8
Old January 21st, 2014, 10:24 AM
Got some work done last weekend… pulled the engine, transmission, transfercase, heater/blower, wiring, brake lines and fuel lines. I just finished my home made A frame, worked really well. Also picked up the SM465 married to an NP205 from a 79’ chevy.
  #9
Old January 21st, 2014, 12:58 PM
Probably should note that I'm building a 3D model using Solidworks. I use Solidworks to come up with a design and work out most of the kinks before I actually start building pieces. Here is the current state of the model. The cab, bed and rear half of the frame are not dimensionally accurate just yet. The forward half of the frame and suspension are spot on.
  #10
Old January 23rd, 2014, 11:18 AM
2many 2many is offline
Basic Trainee
2many is a Soldier
Wow - you can work magic like that on Solidworks but you don't have an accurate way to drill holes! Right with you there except I can't even play with Solidworks. Anxious to see how your build progresses as I'm about to begin something similar. Keep up the good work!
1998 - 2019
Copyright 1998-2019
