Results 1 to 4 of 4
Thread: Tcase/front diff question
    Default Tcase/front diff question
    I have a divorced ford np205 with the driverside drop, if I were to find a D60 ford front dif would this set up work in my M715? Thx might be a stupid question.
    You could make it work but if you didn't swap out the rear axle as well you would end up with different bolt patterns on your rims.
    NorthEast Texas
    I have a d-60 from an 87 f350 in mine. The spring center to center is exactly the same. Just spring over instead of under.
    Is the Ford Dana 60 easier to swap in than a GM 60? I'm talking about the spring pad width. I have a GM 60 and have measured it but haven't gotten close to a Ford 60 yet.
  1. dana 60 front axle and diff swap
    Last Post: April 7th, 2010, 09:13 AM
  2. International Dana 70 front Diff
    By CrashMorriss in forum Modified Tech
    Last Post: October 4th, 2009, 06:41 PM
  3. Front spring question?
    By poolmike in forum Open Discussion
    Last Post: March 20th, 2008, 08:05 AM
  4. How get into front Hubs and Pull rear Diff?
    By HUMMER103 in forum Modified Tech
    Last Post: February 6th, 2008, 04:43 PM
  5. Front-end Shimmy Question
    By joesco715 in forum Open Discussion
    Last Post: February 4th, 2008, 01:28 PM
