Old November 12th, 2009, 12:23 AM
Binford's Avatar
Binford Binford is offline
Moderator
Binford is a Soldier
Default binfordm715 : Troop seat slat progress
Post by binfordm715 on Sept 9, 2006, 10:35pm
I've been working a lot at my next-door neighbor's woodshop getting those ratty old oak boards I got from my customer's scrap pile (my company uses rough-cut oak for crates) prepped for making troop seat slats. This has been an amazing amount of work so far. I'll bet I've got 6 hours into it so far, and the boards are only now cut and planed so we have five squared-off edges from which to work. I don't think my neighbor is too keen on helping me make more of these either as the wood is pretty crappy and dirty and his woodworking equipment is expensive and of high quality!
After pulling apart the crates in the pile outside my customer's chicken house, I lugged them all home and spent a couple hours pulling nails. Since none of the boards was straight, I had to weed out the worst of them and used a 10' board to extend the fence on the table saw, cutting the convex side of the board. Then we'd have a straight edge to use to cut the concave side. Then I could use that straight edge to cut the ends square. Then we ran each board throught the planer. That's where we are now.
Next will be running them through the joiner. Every one of the slats will have a joint in them as there was no way to get straight cuts otherwise. It would have taken a 16' board to extend the fence out, which just wouldn't work. Modern adhesives being what they are these days, I have no problem with joints. Those areas will be stronger than the virgin wood! (Seriously.)
This picture shows the joint we're going to be using. I didn't have a quarter on me, so I had to make use of whatever I could find in my pocket for size reference!
Anyway, that was just a test-cut on a pine board, not the oak. It is not nearly as deep a joint as stock, but this joint is FAA approved for airworthiness (woodworking neighbor is a retired maintenance supervisor for United Airlines, not that UAL uses much wood joinery on 747s or anything....) Point is, the joint will be plenty strong, if not stock-looking. Likely 40 years ago they needed such deep joints for strength due to the lack of the types of adhesives we have today.
Here's the rack of boards we've cut. There are even more down below, out of the picture.
They range in thickness from about 7/8" to 1-1/4". We'll match boards up of similar thicknesses and grain patterns (I'm staining mine, not painting them, so I want the grains to match as well as they can), then run them through the router to cut the joint in the end of one, then flip the other over and run it through the same bit. When flipped back over, they will line up perfectly. Then they'll be glued and clamped together. Once cured, we'll cut them to their 3-inch width and then run them through the planer until they're 3/4" thick. Then we'll cut the lengths down to 87 inches and router the corners and ends. Finally mark and countersink the mounting bolt holes, then stain them with a dark walnut finish, spray semi-gloss urethane on them and mount them up. A lot of darn work.
Moderator
PseudoZone is a Soldier
Default thetroublemaster :
Re: Troop seat slat progress
Post by thetroublemaster on Sept 10, 2006, 1:32am
Sweet Tim. We expect a full write up to add to your work load...LOL..
k8icu's Avatar
k8icu k8icu is offline
Sergeant
k8icu is a Soldier
Default k8icu :
Post by k8icu on Sept 10, 2006, 11:03am
I thought you had the revolver out as a way of saying that "I want to blow my brains out for doing this."..... LOL
Use Gorilla Glue they will never come apart!
fisherman's Avatar
Sergeant
fisherman is a Soldier
Default fisherman :
Post by fisherman on Sept 10, 2006, 11:15am
Great Job Tim, now can you just imagine restoring and doing this to your whole truck. How many sets of slats will you be making?
FSJGuy FSJGuy is offline
Private 1st Class
FSJGuy is a Soldier
Default fsjguy :
Post by fsjguy on Sept 10, 2006, 11:48am
HOLY COW! That is a TON of work. I bet it'll look REALLY nice when you're done.
  #6
Moderator
Default bbm715 :
Post by bbm715 on Sept 10, 2006, 10:28pm
Good work Tim.
Better be REAL nice to that neighbor!
  #7
Binford's Avatar
Moderator
Post by binfordm715 on Sept 12, 2006, 10:39pm
With this wood, I'm afraid just the one, with a few spare boards. Using pine boards or even 5/4" cedar decking boards or whatever, my neighbor said he'd help me whip out as many as I want, as it would be a lot easier on his equipment.
You're not kidding! AND he has a brand new Kubota tractor that he literally INVITES me to borrow! Serioulsy. He came by the house one day and asked, "Didn't you say you needed to do some trenching?"
"Yeah," I said, "eventually. I've just been too busy with other stuff to get to it."
"Oh. Okay. Well, the tractor's there when you're ready!"
My only regret is that there's so little I am able to do for him in return! Watch his dogs when he's gone and such is about it. And I roto-till his garden every spring. Usually Jennifer ends up cooking a nice Chinese dinner and we invite them over to help pay them back for all their generousity.
Oh! And last week I bought one of those Costco canopies for him so he can park the tractor in it, before the rains start. He's had it outdoors. I think that gesture went a long way.
HTML code is On
binfordm715 : Birth of troop seat slats Binford PseudoZone - Open Archive 3 November 11th, 2009 12:10 AM
binfordm715 : Troop seat wood specs Binford PseudoZone - Open Archive 31 November 10th, 2009 11:16 PM
Troop Seat Paint Barrman Modified Tech 11 May 10th, 2008 10:55 AM
Troop seat paint stranman Stock Tech 7 March 11th, 2008 01:18 PM
