Results 1 to 9 of 9
Thread: is there a easier way to get the spark plug wires out
    Oct 2019
    Rock Valley Iowa Sioux County
    Exclamation is there a easier way to get the spark plug wires out
    Hi im a highschool student work on an M-715 1-1/4 ton truck at my school but is there an easier way to get the spark plug wires off I've got two off but I can't get a wrench down there to unscrew them. Pls, help. I need because I can only work after school because my ag teacher is leaving
    Here is a picture of the correct wrench as listed in the service manual.
    You could modify a box wrench by cutting the side out, but you would need to be able to heat it up, to put a bend into it.
    Oct 2019
    Thanks for the help i will do that.
    You can actually make a wrench. I used an old boxed end wrench and heated with a torch to bend the end. Then cut the notch with a cut-off wheel. Then ground down the sides for a little more clearance. Works better than the one I bought.
    Got more questions, just ask. And post a pic or two.
    Jan 2011
    Fernandina Beach, FL
    Here is what I had in 1969:
    Available on eBay item # 383231885948
    Not mine, no affiliation and it is about $15 shipped.
    I believe I got one of those. If be surprised if there are any left. It works great for wires, but I have not figured out a great way to remove plugs with it. It's probably just me.
    1968 M-715 w/1100R16s on Stockton wheels, H3 headlights, 2bbl upgrade...
    Jan 2011
    Quote Originally Posted by TJinSD View Post
    This wrench is for removing the plug wires from the plugs and ignitor. You use a regular deep socket for the plugs.
    I got mine from ebay. The seller had four or five for sale. $15. I got it a few months back so I don't know if he has any left.
