Results 1 to 4 of 4
Thread: Axle U-Bolts
    Default Axle U-Bolts
    Where is a good place to get replacement axle U-bolts? I will need new for all 4 corners, I didn't know if the ones for the rear would be hard to find since they have a bend in them.
    The front and rear sizes are standard...the rears are actually straight in the NOS stuff...have to be bent before installation...
    If you have a spring shop around, they can do it easy.
    Ok, that works, I figured on buying ones that were similar and bending them myself anyways.
    If you have the stuff to bend them, be my guest and save yourself a few bucks too!!
  1. maddawg308 : Size of fron and rear axle u-bolts?
    Last Post: November 12th, 2009, 01:37 AM
  2. nuts and bolts
    Last Post: August 16th, 2009, 08:24 PM
  3. hub bolts?
    Last Post: August 28th, 2008, 09:48 PM
  4. u bolts
    Last Post: October 22nd, 2007, 07:43 PM
  5. u-bolts
    By Doug in forum Stock Tech Archives
    Last Post: April 29th, 2004, 04:20 PM
