Results 1 to 5 of 5
Thread: k8icu : Stock Battery
    Default k8icu : Stock Battery
    Stock Battery
    Post by k8icu on Sept 16, 2006, 5:40pm
    Did the M715 use the 2HN or the 6TN batteries?
    If it was the 2HN which I think it was, does anyone have any data on them? Amps, Height, Width, Length...etc.
    SF Bay Area, CA
    Default hiker :
    Re: Stock Battery
    Post by hiker on Sept 16, 2006, 8:09pm
    2HN batt's were stock but I run a couple of group 24 batts that work. The spec on the 2HN:
    Cold crank 400, reserve cap 75, weight wet 34lbs, dry 25lbs, length 10.25, width 5.25, height 9
    link here: http://www.oksolar.com/battery/deka_military.htm
    PDF link here: http://www.oksolar.com/pdf/components/deka_miliatry.pdf
    Default k8icu :
    Re: Stock Battery
    Post by k8icu on Sept 16, 2006, 8:29pm
    Thanks Hiker. I would have thought they had more power than that. 400 cold amps is rather low.
    SF Bay Area, CA
    Default hiker :
    Re: Stock Battery
    Post by hiker on Sept 16, 2006, 8:35pm
    It's a small batt compaired to most. The closest civilian battery that fits the M38A1 is something out of a sports car. The M715 will fit almost any car batt. I've seen the 2HN's sell on ebay fairly resonable price, dry charged, but shipping is a killer.
    Default k8icu :
    Re: Stock Battery
    Post by k8icu on Sept 17, 2006, 9:54am
    I'm going to try to find a civilian equivilant in size and when I do I'll post up about it.
  1. Battery Box Lid
    By krek in forum Stock Tech
    Last Post: June 15th, 2007, 09:48 PM
  2. Stock specs for stock axle, wheel, brake drums & tires
    By brute4c in forum Stock Tech Archives
    Last Post: May 31st, 2007, 09:46 AM
