Old December 15th, 2009, 04:44 PM
wrecker's Avatar
wrecker wrecker is offline
Sergeant
wrecker is a Soldier
Default wrecker : sbc 350
sbc 350
Post by wrecker on Sept 16, 2006, 10:17am
'Sup y'all? I'm running a chevy 350 w/ HEI, sm420, stock T-case and axles. The last couple times I've run the truck, it runs great while it's cold, then starts acting like it's not getting enough fuel or losing fire after it warms up. The choke is not hooked up and this is a new problem so I don't think it is choke related. Since it only happened at first when it got warm, I'm kinda scratching my head. It's doing it all the time now-cold or hot. I was thinking of changing the fuel pump, filter, and dropping the tank to see what kinda crap might be blocking the fuel pick up line. My crappy battery connection shouldn't affect the fire since the truck will run w/o the battery hooked up. Anyone have any other ideas? Thanks, Bill
compexp's Avatar
compexp compexp is offline
Sergeant
compexp is a Soldier
Default compexp :
Re: sbc 350
Post by compexp on Sept 16, 2006, 10:57am
egr valve
Old December 15th, 2009, 04:45 PM
wrecker's Avatar
Sergeant
Default wrecker :
Re: sbc 350
Post by wrecker on Sept 16, 2006, 11:01am
I shoulda mentioned, it's a total non emmissions engine from the same era as the truck.
Moderator
PseudoZone is a Soldier
Default scottm715 :
Re: sbc 350
Post by scottm715 on Sept 16, 2006, 11:11am
You should check a couple things, look at the flaper plate of the choke to make sure it is no falling closed, the check fuel line to make sure it is not vapor locking, this happenswhen it is run next to a heat source which causes the fuel to heat up in line and vaporize. also pull the plugs and check for fouling, oil/fuel fouled.
Moderator
Default thetroublemaster :
Re: sbc 350
Post by thetroublemaster on Sept 16, 2006, 11:22am
Possible carb icing? It can happen at out side temps as high as 74 degrees. Sounds like its doing it all the time even when thoughly warmed up. So most likely not icing. Get your choke fixed though.
  #6
Moderator
Default bbm715 :
Re: sbc 350
Post by bbm715 on Sept 16, 2006, 5:04pm
I'd check the plugs first, then replace the cap & rotor then check out the wires and if its still doing it I'd check the coil.
Wait, first I'd change the fuel filter ('cause its easy & cheap) then I'd do the rest.
  #7
Moderator
Default moosejr :
Re: sbc 350
Post by moosejr on Sept 17, 2006, 2:00pm
check the carbon tip inside the distributor cap that goes direct to the coil. I have seen the carbon go bad, and the symptoms were exactly as you described, including the history, .. .. . good luck. .
  #8
wrecker's Avatar
Sergeant
Default wrecker :
Re: sbc 350
Post by wrecker on Sept 18, 2006, 11:28am
Thanks for the tips, hopefully I can get a spare evening to work on it this week. Bill
  #9
Moderator
Default m715akacharlie :
Re: sbc 350
Post by m715akacharlie on Sept 21, 2006, 7:16pm
I had the same problem with my 350 there is a fuel line getting hot and it is causing your carb to vaperlock . check the fuel lines running close to the exhaust
HTML code is On
wrecker : GMC v-6 305 wrecker PseudoZone - Open Archive 12 November 11th, 2009 10:24 PM
wrecker : Rapco (Tim) wrecker PseudoZone - Open Archive 22 November 11th, 2009 12:43 AM
Insurance Sources for a 5 Ton Wrecker Rumplecat Open Discussion 6 January 29th, 2007 08:24 PM
