Results 1 to 7 of 7
Thread: porkchop : Jackshaft (intermediate shaft)
    Default porkchop : Jackshaft (intermediate shaft)
    Post by porkchop on Oct 11, 2006, 2:57pm
    I need one for my truck. I can get one from Lucky but it will need to be shortened and even then it might not be able to be shortened enough. What I am looking for is a good list of trucks that I may be able to get one from. The distance from center to center is 8 1/4" The xmsn has a 1350 yoke and the NP205 that I will be installing does as well. So where should I start looking?
    Default brute4c :
    Re: Jackshaft (intermediate shaft)
    Post by brute4c on Oct 11, 2006, 3:10pm
    74 or so Dodge truck, I think the 3/4 ton and up....has a divorced 205 with a jackshaft...
    El will probably know the years better, but there are a couple years around that one that may have it...
    Default porkchop :
    Post by porkchop on Oct 11, 2006, 3:20pm
    How long is the shaft?
    Default brute4c :
    Post by brute4c on Oct 11, 2006, 3:29pm
    I dont know offhand...my brother had one and thats how I know...but I never measured...
    Default barrman :
    Post by barrman on Oct 12, 2006, 8:51am
    I will try and measure my '66 Chevy 3/4 ton tonight. It has the divorced Rockwell t-case behind a SM420. I saw at least 4 or 5 like it on my drive over the weekend, so I know there are some in your area.
    Default porkchop :
    Post by porkchop on Oct 12, 2006, 9:07am
    Thanks, that will help a lot. I just need a starting point of where to look.
    Default elwenil :
    Post by elwenil on Oct 12, 2006, 9:18am
    The shaft on the 70's era divorced case Dodges is about 13" long and it a bit longer then the normal M715 shaft. It also uses Detroit style joints so the yokes would all be different. For what it's worth, pre-1975 Dodges all had divorced cases, half ton included. Some of the 60s models should have used the Spicer style joints, but finding a shaft worth a crap from one of those might be tricky even if you can find one of the trucks. I finally nit the bullet and had a shaft made for my W100 when I put the big block in since it wasn't easy to find another replacement.
  1. porkchop : Pretty
    By porkchop in forum PseudoZone - Mod Tech Archive
    Last Post: December 15th, 2009, 08:17 PM
  2. porkchop : NP205 mounting
    Last Post: December 15th, 2009, 07:54 PM
  3. porkchop : Throttle linkage?
    Last Post: December 15th, 2009, 07:52 PM
  4. porkchop : retubing a driveshaft
    Last Post: December 15th, 2009, 07:49 PM
  5. Jackshaft
    By porkchop in forum Modified Tech
    Last Post: December 27th, 2006, 02:46 PM
