Results 1 to 7 of 7
Thread: Did the airforce use m725's?
    parsons Kansas
    under the hood of mine it says something about airforce ? Ill check and see exactly what it did say.
    what would the markings be if its from the airforce? I would eventually like to get it as close to it was, newly painted and put into service.
    All I can tell you is that I have seen an M715 that was used by the Air Force originally...as to markings, that would be dependant on what outfit had the truck and what there markings would be...I wish I knew mine...
    Good luck!
    i have DOOR marking info, size and stuff from mine, a pic too.......
    Oxford, Maryland
    The Air Force did use M725's. My first was an Air Force truck (2 air conditioners). Don't know if the USAF came by these thru excess from another service or received them originally.
  5. Default Hub seals on e-bay
    I believe Doug(JeepistDoug/IA)mentioned that the truck I'm getting was once used by the Air Force. said something like "Air Force---Official Use Only" on the doors. Hopefully it will be here(Tx)next week!!!!!!!!!!!
    1969 M715
  6. Default
    oh!,it's not a 725 though.
    1969 M715
    San Antonio,Texas
    Quote Originally Posted by bdial
    air conditioners?
    please explain
    k
    67 M725 84 GW
  1. M715's M725's Near Frederick MD
    By randyscycle in forum Open Discussion
    Last Post: August 21st, 2007, 10:12 PM
