Results 1 to 10 of 20
Thread: gaskets under door handles, door panel clips, widow clip
    Feb 2007
    Spring Hill, FL 34610
    Default gaskets under door handles, door panel clips, widow clip
    looking for the gaskets that go under the outside door handles, also the clips that hold the door panels on, and the clip that holds the widow regulator to the window frame, what door rubbers should i run?
    Default Parts
    Door panel clips can be found at a body shop supply. They are Au-ve-co 10831. Black, 11/16 Head, 5/8" long, 5/16 Diameter. They work fine as is and better if you put a washer under the head. If you can't find them, I may have a box here. The gaskets from under the handles show up on e-bay from time to time, where I got mine, and I have also seen them at one of the Jeep catalog/online parts stores but can't remember where.
    Door handle gaskets are the same as any FSJ. As are the doors themselves once you remove the window frame & such.
    Oct 2008
    north florida
    BJs has most of what you need. I got my door handle gaskets from them.I am attaching link to the door handle gaskets. From there you can look at their weather stripping . http://www.bjsoffroad.com/CartGenie/prod-490.htm
    Quote Originally Posted by jpsnblood View Post
    Yep, that's it. BJ's offroad. He was selling them on e-bay also.
    Washington State
    Restoration Specialties in Pennsyvania has the exact door panel clips you need for the stock metal door panels. I couldn't tell them from stock. They appeared identical. You can google them, they have an extensive website for all kinds of weather stripping and auto fasteners. Bj's Offroad here in Washington has been great to deal with. He will have the rest of what you need.
    Feb 2007
    thanks for all the replies, what about the door rubbers?
    I just spent a lot of time looking for some hard to find stuff online. I found several sites that had multitudes of gaskets for doors. I was not looking for door gaskets but saw many. JC whitney has a great assortment. I was looking for some buick specific parts and found gaskets galore. My 69 wag has the older style like the M715. I have no worries about finding the exact match. Google GM door gasket. Just get a side profile of what you need.
    Try Metro..
    http://www.metrommp.com/
    These guys are cool also. For you CJ guys, I think it was fairchild that has the CJ gasket between the WS and the body with a high durometer rating meaning not spongy like the garbage you get from crown and similar.
    http://www.fairchildind.com/app/vehi...s.asp?part=646
    Need a rubber bumper for your glove box door? For example, I found the little rubber bumper just inside the door upper corner on the tub of my old m715.
    http://www.rubber-group.com/bump.html
    There are rubber products out there. Actually a lot of them. The older hot rod parts sites are a great resource.
    Don't skimp on the glue or the directions on applying it.
    Post what you find especially if it's a perfect match for the resto nuts and
    get famous for a few minutes.
    Liz, covid, murdered 10/19/21
    Here is JC whipme. They have a lot more than it looks.
    http://www.jcwhitney.com/MOLDED_SPON...;N;2008603;0;0
    or even better
    http://www.jcwhitney.com/jcwhitney/t...&shopid=100001
    I had these guys saved in my bookmarks also. They have a lot all at one site.
    https://secure.steelerubber.com/homeframes.html
  1. rpgdeity : Door regulator clip?
    Last Post: November 11th, 2009, 01:47 AM
  2. Door Panel Clips
    By rboltz in forum Stock Tech
    Last Post: September 17th, 2008, 12:28 AM
  3. Door Panel Clips
    By fisherman in forum Stock Tech
    Last Post: December 26th, 2007, 09:10 PM
  4. Door handles with locks.
    By tngreenmachine in forum Open Discussion
    Last Post: March 19th, 2007, 10:39 AM
