Results 1 to 10 of 15
Thread: LED tail light conversion
    Default LED tail light conversion
    Okay, I took a set of front turn signal lights that Saxon was kind enough to give me and cut out the center of the cap for an LED tail light conversion for my CJ-5. Here's a picture of what DP had done with his M715 as posted in another thread:
    Now, here's what I am left with after using a 4" hole saw on a drill press:
    Note that mine seems to be cut out without any "flange" left to hold in the LED light. DP, is this pretty much what you ended up with?
    There's a ring on the inside that's exactly 4 inches in diameter. The hole saw fit exactly inside that. Yet from the outside, it looks like yours has more of a break-over. A lip that would hold the light in place. On mine, it looks like I will have to glue my LED light in because there's no lip to hold it in. Did I do something different? The front turn signal cover can't be a different size than the tail lights you used...could it?
    -- Tim Taylor
    There is a grommet that makes up the difference isnt there?
    woodland ca
    that is a great idea!
    my signature is sweet huh?
    Grommets visible here look like what you see on DP's lights:
    No, DP removed the grommets to install his.
    -- Tim Taylor
    Nov 2008
    Tacoma, Washington
    Did you all remember to apply ant-seize compound to those new taillight flange screws??
    Jester Guest
    I was thinking of making up a set of these too.
    DP's ring definitely as a "lip" on it.
    His full install is on his web page.
    http://www.sanlee.com/jeep/MSeriesLights/MLights.html
    Yeah, I read that. But 4 inches is 4 inches, eh? It's just that on the front turn signal lights, those 4 inches don't leave any lip.
    It'll work just fine. Just won't hold it in like I wanted (as DP's does). Nothing a little adhesive won't fix though.
    -- Tim Taylor
    Jester Guest
    Quote Originally Posted by Binford View Post
    Whoever told you that was just trying to cheer you up...
    Tim, why crap up the housing with adhesive? Can't you drill a hole or 2 or 3 in the bezal and install "set screws" to hold it in place?
  1. Another 12v blackout hood light conversion
    By randyscycle in forum Modified Tech
    Last Post: March 3rd, 2021, 06:41 AM
  2. tail light brackets
    By jkrobbie in forum Stock Tech
    Last Post: April 23rd, 2009, 03:06 PM
  3. Tail light feedback
    By SHOOTER68 in forum Open Discussion
    Last Post: October 11th, 2008, 08:51 PM
  4. Who was making the aluminum tail light rings?
    By Binford in forum Open Discussion
    Last Post: June 19th, 2008, 11:57 PM
