Results 1 to 4 of 4
Thread: rear rubber brake line
    Exclamation rear rubber brake line
    does anyone know where to get a rear brake line, the rubber one . from like napa or some other parts store . any help would be great.
    No, dont have any info on that...could try taking yours there and seeing if anything is close...as long as the ends are the same and the lengrh is at least the same as the stock one, could be longer but not shorter, you would be good to go.
    There are places that make them from braided stainess and such...like at hydraulic shops and such...possibility.
    I tried the NAPA route with no luck. I bought mine from AB Linn. Memphis Equipment has them also.
    Warthog
    One thing I would be concerned about buying mil surplus:
    If the hoses are 40 plus year old NOS ones, I dont know how much I would want to trust them. If they have new manufacture...at least in the last several year, ok...but late 60's/early 70's stuff....not for brakes I need to keep from geting seriously hurt, hurting or killing someone else...etc.
  1. Brake line diameter??
    By DivingKaiser in forum Modified Tech
    Last Post: April 6th, 2010, 07:23 AM
  2. fisherman : Brake line pressure switch for brake lights.
    By fisherman in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 12:33 AM
  3. Rubber (or flex) brake lines?
    Last Post: June 6th, 2008, 11:41 AM
  4. brake line to master cyl. ??
    By Elohim1 in forum Modified Tech
    Last Post: February 9th, 2007, 12:00 AM
  5. Longer rubber brake lines...where to buy?
    By Nuke_spicergear in forum Modified Tech Archives
    Last Post: May 25th, 2004, 11:50 PM
