Results 1 to 10 of 17
Thread: 40GRIT Hydro-clutch pix
    Default 40GRIT Hydro-clutch pix
    40GRIT,
    I finally got the camera and figured out the pix posting. You've likely completed your clutch task at this time, but I wanted to follow through with your request anyway. Here's the clutch set-up in the truck.
    If you'd like pictures of another angle, let me know.
    Richboro,Pennsylvania
    I see. That gives me some idears...
    May 2004
    Anchorage, Alaska
    MM,
    thank you sir, and no, I haven't made much progress, been working 7/12's during an outage, so theose are good, pics... can you read any numbers off the master and slave? let me give the pics a good looking and see if I come up with some more questions....
    thanks again, great of you to remember...
    May 2004
    Anchorage, Alaska
    Btt
    Washington State
    Abrasive one what application or part # is your brake master, and the bore size. I need one. Thanks for the pictures.
    May 2004
    Anchorage, Alaska
    psst, Todd the fisherdude, those are markness monster's pics of a truck he bought from someone that has a NV4500, I'm trying to still piece mine together, but i'll pass on any info he is kind enough to find...
    40Grit:
    The clutch master cylinder used is a "Wilwood Disc Brakes" remote master cylinder kit. Part number 260-3374. This is a 3/4" combination master cylinder kit (1.1 stroke).
    A 7/8" C.M.C. kit (1.2 stroke) is part number 260-3376
    A 1" C.M.C. kit (1.0 stroke) is part number 260-3378
    In regards to the slave cylinder, I do not see any identification marks on the assembly. If you need more information, don't hesitate to ask.
    Washington State
    Thank you, that's what I needed to know. My slave is 7/8 bore so either of those would probably work.
    Edit
    May 2004
    Anchorage, Alaska
    thanks markness monster..that's good info
    Todd, what slave have you got? does it look like the one in the pics?
  1. 40grit : Brake line ID w/ progress pics
    By 40Grit in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 04:26 AM
  2. 40grit : Receiver Hitch from RV( pics for Timmah)
    Last Post: November 11th, 2009, 04:24 AM
  3. hydro boost question
    By mudslinger in forum Modified Tech
    Last Post: August 26th, 2009, 10:13 AM
  4. Hydro clutch
    Last Post: March 24th, 2009, 12:46 AM
  5. Full Hydro vs hydro assist
    By jeepcj in forum Modified Tech Archives
    Last Post: April 9th, 2004, 01:39 PM
