  #1
Old May 11th, 2019, 03:02 PM
Old_Red_Jeep's Avatar
Old_Red_Jeep Old_Red_Jeep is offline
Private
Old_Red_Jeep is a Soldier
Default Piecing together a brake system
All,
I'm trying to put together a brake system for my 715 and I've run into a snag. It currently has the E250 van wheel cylinders and the corvette MC. Since I'm rebuilding the whole truck, I'd upgrade to power brakes. I got a holt of a booster and MC out of a wagoneer but it interferes with the V10 I'm installing. If I go the universal booster and MC route, I'll need to know what size bore the jeep MCs are. Does anybody have that info? I haven't been able to find it. Should I use the bore of a M715 factory MC or the bore of a the boosted MC? I'll need a smaller diameter MC but I think I'll probably wind up with a dual diaphragm. I'm sure your answers will generate more questions on my end. Thanks for the info!
__________________
@hayeselmotors
  #2
Old May 12th, 2019, 06:11 AM
Grendel Grendel is offline
Basic Trainee
Grendel is a Soldier
If you have a Corvette MC and it works with what you have, why not go with the powered version of it?
  #3
Old May 12th, 2019, 10:52 AM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
A hydro boost upside down will work just fine in that position and might clear your V10. You will probably need to put a spacer/plug in the master cylinder shaft slot to let the hydro boost push rod connect to the master cylinder correctly.
Do you have the Jeep booster mount block? It is an angled wedge that actually tilts the master cylinder up a touch.
__________________
  #4
Old May 13th, 2019, 10:34 AM
Private
It does have the aluminum spacer on the back of the diaphram. Does the corvette master cylinder have the right bore for the drums? I can't remember what year people recommend for that. is it the MC from a 74 corvette?
__________________
@hayeselmotors
  #5
Old May 13th, 2019, 11:11 AM
Private
Nevermind, I found it. Looks like a MC from a 76 vette will work with the corvette booster. I'll get a proportioning valve and it should all be ok. hopefully. thanks fro the help.
__________________
@hayeselmotors
1998 - 2019
Copyright 1998-2019
