Old November 11th, 2009, 12:07 AM
Moderator
PseudoZone is a Soldier
Default ricepaddycaddy : Master Cylinder Upgrade
Post by ricepaddycaddy on Jun 18, 2006, 12:29pm
Hey guys, which master cylider is used in a M715 to upgrade its brake system? Thanks.
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
Default barrman :
Re: Master Cylinder Upgrade
Post by barrman on Jun 20, 2006, 9:44am
Do you want to stay stock or go to a dual line mc?
Old November 11th, 2009, 12:08 AM
teking teking is offline
Private 1st Class
teking is a Soldier
Default teking :
Post by teking on Jun 20, 2006, 11:43am
i have a 70s dual Corvette MC on my truck.
bluesman2a bluesman2a is offline
Private 1st Class
bluesman2a is a Soldier
Default bluesman2a :
Post by bluesman2a on Jun 20, 2006, 2:21pm
69 corvette with all wheel discs.
You need to run two separate lines for front/rear.
Private 1st Class
teking is a Soldier
Default teking :
Post by teking on Jun 20, 2006, 2:24pm
Same one I have! How is your peddle travel before braking begins? Are you using the stock rod?
  #6
Private 1st Class
Post by bluesman2a on Jun 20, 2006, 3:18pm
I'm using the stock rod and before all my upgrades the pedal was firm, but sat very high. I now have an FSJ automatic (wide) brake pedal, so we'll see how it changes. I've also upgraded to 4 wheel discs, so that will be a change also.
  #7
Barrman's Avatar
Chief 9-flats
Default barrman :
Post by barrman on Jun 20, 2006, 3:21pm
1976 was the last year that Corvettes were available with non power assisted disc/disc brakes. The mc from that year and some years before it is a great upgrade to the M715. Both lines have the same piston diameter so equal pressure is sent out. You need to make a new line that goes near the block the brake light sender is currently mounted. Disconnect the rear brake line from that block. Plug the hole and connect your new line from the mc to the rear line. Bleed the brakes and drive.
Unless you lengthen the brake push rod about 3/4", you will have a low pedal before you even start to apply pressure to the brakes. Many have cut the stock rod, added metal and rewelded. I have done this swap and didn't lengthen my push rod because I plan to add Hydroboost in the future and don't want to figure it out twice.
  #8
Moderator
Default robertcowan :
Post by robertcowan on Jun 20, 2006, 9:59pm
do you guys know any truck on the market or ever been on the market with a master cylinder the size of a vette m/c. i dont see the logic. put a truck m/c on a truck. cost is the same , probably cheaper.
bob
  #9
compexp's Avatar
compexp compexp is offline
Sergeant
compexp is a Soldier
Default compexp :
Post by compexp on Jun 20, 2006, 10:42pm
I used a Cardone unit - I'll have to try and find the part number, but it was only $12 or so. Added a dual master cylinder adapter from NAPA and ran an extra line from the master to the rear brake line. Capped off the original rear feed from the proportioning valve.
This is a non-power cylinder but works well.
HTML code is On
Master Cylinder Conversion - Upgrade Warthog Modified Tech 36 August 26th, 2011 12:18 PM
Stock master cylinder countcv61 Stock Tech 10 March 4th, 2010 02:59 PM
gimpyrobb : Master cylinder gimpyrobb PseudoZone - Open Archive 2 November 11th, 2009 01:32 AM
m-715 master cylinder upgrade razrbacman Open Discussion 15 May 2nd, 2008 05:09 PM
master cylinder Q. kaiserkoski Stock Tech Archives 7 April 27th, 2004 06:40 PM
1998 - 2019
Copyright 1998-2019
