Old November 12th, 2009, 03:05 AM
Moderator
PseudoZone is a Soldier
Default wi715 : Lubriplate 630-AA grease
Post by wi715 on Nov 22, 2006, 8:21pm
I'm currently in the process of rebuilding a Garwood 10K winch off of a M35. I want to use it as an assembly lube. Any problems with this?
I got 6 pound bucket at an auction for $2.00
Here some info I have found,
http://www.lubriplate.com/Products/MultiPurpose.htm
http://www.f-bacon.com/lp-g630.htm
John
Moderator
Default tacomainoh :
Re: Lubriplate 630-AA grease
Post by tacomainoh on Nov 22, 2006, 11:26pm
I wouldn't use it for anything supercritical until I found out what "bentone" means. LOL
I have to start on rebuilding my winch as well, have you found any helpful manuals/websites??? I d/l'ed the relevant TM's off Steel Soldiers already.
Moderator
Default wi715 :
Post by wi715 on Nov 23, 2006, 1:35am
I have the 630 not 930 type.
BENTONE GREASE IS A NON-SOAP THICKENED GREASE
There are many types of these non-soap thickeners, the most common is bentone. Bentone clay grease is used in high temperature application.
Some info I found WAS on tpub.com but not anymore. Found the manual again on Steelsoldier
http://www.steelsoldiers.com/index.php?m....fid=file&pid=76
Look at chap 16.
Took me over an hour to download. Man I hate dialup.......
John
Elwenil's Avatar
Elwenil Elwenil is offline
Private 1st Class
Elwenil is a Soldier
Default elwenil :
Post by elwenil on Nov 23, 2006, 9:08am
Lubriplate is basically white lithium grease. It was used for years as an assembly lube in engines before better things came along. Some old timers will still use it as cam break-in lube, which I do not think it is well suited for, personally. At any rate, white lithium is great for small mechanical gears and motors that use both metal and plastic gears. A good example is power window motors and regulators. I wouldn't use it in a winch, but it does have a lot of other good uses. For the winch, I'd only use what is recommended by the military. Just my .02
Old November 12th, 2009, 03:06 AM
Moderator
Default wi715 :
Post by wi715 on Nov 23, 2006, 9:42pm
What would you use?
I plan on using 80w-90 gear lube. I want something to lube the seals and bushings on the drum shaft which is above static gear lube level.
John
  #6
Elwenil's Avatar
Private 1st Class
Default elwenil :
Post by elwenil on Nov 24, 2006, 8:22am
Check this thread: http://m715zone.proboards102.com/index.c....read=1163626805
It has two links in it that have the manuals on PDF files that can be downloaded that tell you everything you need to know about servicing and operating that winch. I wouldn't use anything other than what the military recommends for it.
  #7
Moderator
Default twostorms :
Post by twostorms on Nov 26, 2006, 12:37am
Give me a day or two and i will see if i still have a military lube tech manual from when i was still in the Seabee's. It should have military and civilian equivalents of what your looking for since i worked on construction equipment then
Just have to dig through the my pile of junk first
  #8
Elwenil's Avatar
Private 1st Class
Default elwenil :
Post by elwenil on Nov 27, 2006, 9:27am
Steelsoldiers has just about every manual available now through LOGSA as well as a lot of older, out of print manuals. The link I posted above has the link to the proper winch manual.
HTML code is On
Grease Guns rboltz Open Discussion 14 October 4th, 2009 01:42 PM
front axle shafts grease..... BCOWANWHEELS Stock Tech 15 August 30th, 2007 04:21 PM
1998 - 2019
Copyright 1998-2019
