Old April 30th, 2019, 05:18 PM
Rumplecat Rumplecat is offline
Rumplecat is a Soldier
Default Wheel Spacers for M998 Wheeels & Tires
I know,I have searched but I need info. more recent than 2007! I have four sets of 37X12.5X16.5 tires and wheels I want to put on a 715 and a M37. What spacer so I need to do this on the 715?
Old May 1st, 2019, 02:57 AM
ray steadward ray steadward is offline
Private 1st Class
ray steadward is a Soldier
Spacer? You would need an adapter or have the wheel recentered....
Is that real money?
Old May 1st, 2019, 06:58 AM
venominjected's Avatar
Corporal
venominjected is a Soldier
We are assuming you already did an axle swap correct?
1967 M715, 6BT, ZFS542, NP205
Old May 2nd, 2019, 09:39 AM
Negative, stock axles. I used a spacer/adapter on my CUCV to use the wheels/tires now I want to do the same thing on one of my 715s and I plan use a set on a M37 as well, once I find the correct adapters/spacer for both, if such a thing is available.
Jameshttp://www.m715zone.com/vb/attachment.php?attachmentid=1364&stc=1&d=155681510 9
Old May 3rd, 2019, 06:38 AM
jpsnblood's Avatar
jpsnblood jpsnblood is offline
Private 1st Class
jpsnblood is a Soldier
I found a company advertised in a sport/custom truck magazine that claimed they could make custom adapters
I spoke to a gentleman from the company
He spoke as if it wouldn’t be a problem
I went out a began to measure and discovered the hub center on the rims I wanted to use were a little to smalll
Adapter our not they wouldn’t fit on hub
My 715 is on the back burner right now
But I completed another Jeep that I had the same problem
I was able to have a machine shop remove a few thousandths and everything is golden
If I can find that manufacture’s info
I will send it
  #6
Old May 4th, 2019, 02:09 PM
Thanks, I had hoped there was a ready made adapter out there like I found for the CUCV!
  #7
Old May 5th, 2019, 06:30 AM
jpsnblood's Avatar
Private 1st Class
Boss I did a quick google search
Man the heavy truck type adapters are pricey
I was looking at the 8 lug to 10 lug adapters
They were a couple hundred dollars a piece!
If you add the custom word to the order it will probably get to the point it makes no sense
I ran adapters on Jeep TJs and XJs
They were only $120 a pair
  #8
Old May 6th, 2019, 09:39 AM
A set of four for my CUCV was a little over $200! It is rated at 1.25 tons like the M 715, is it just a demand issue on cost and availability?
1998 - 2019
Copyright 1998-2019
