Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: m715 cummins 4bt fuel milage
  1. #11
    its one wire to the fuel cutoff, thats it
    nv4500 trannt. used stock crossmember and 5 inch channel iron
  2. #12
    well now, it uses a chevy or dodge tranny? either one should be easy to find here. there are only about a 100 salvage yards in a fifty mile radius from me.
  3. #13
    only one wire? did you use the harness from the frito lay truck?
  4. #14
    oops. its a dodge tranny (late chevys use the dodge bolt pattern, iirc. the thing is i had a gm 2wd output put on it
    the one wire that goes to the distributer on the 230 now goes to the fuel cutoff. works fantastic.
  1. M715 Fuel Tank
    By KMMHLP in forum Open Discussion
    Last Post: December 5th, 2012, 06:06 PM
  2. robertcowan : any 6bt cummins in a m715
    Last Post: November 11th, 2009, 02:47 AM
  3. Cummins m715
    By CHRIS UNGER in forum Modified Tech
    Last Post: November 3rd, 2009, 04:27 PM
  4. Cummins in M715
    By Mikel in forum Modified Tech Archives
    Last Post: April 27th, 2004, 11:27 PM
