Results 1 to 6 of 6
Thread: A/C Installation
    Default A/C Installation
    http://www.photodump.com/maingear80/...6b236.JPG.html
    10" pipe was used as the bracket body so there would be enough room for the alternator to be accessed. Pipe will spring out when cut with torch and bend back will be needed to achieve original shape. Attach points were shared with PTO mount and upper alternator bracket. This mount is installed with minimal change to the original engine. Only one bolt is increased in length - the upper alternator support bracket.
    Bracket is installed first then attach leads & belts to Alt. It will be positioned 3" forward of normal position to ease belt installation. Alternator is then placed in factory hole, mount bolts are then installed. Belt is driven by crank only at this point. I don't know what the water pump can take.
    Compressor is out of a 92 V6 pathfinder. Tensioner bracket is from a Sterling sedan V6 British car? (first I've ever seen in the states) Had a serpentine belt - had to change pulley, attach, & tension bolt, taken from a Mazda p/u
    I cut the Nissan bracket because I was to lazy to fab my own, and welded it to the pipe. Used twine to ensure alignment, keeping it in the center of all pulleys.
    P/S pump can be used as a tensioner. I need the workout.
    A/C pack is a rear Toyota sienna 2000 a/c unit. Installed the front heater core in this pack. Welded original heater top housing with plastic welder to keep things air tight. Have not decided on duct route yet. Will post again when installed.
    Jun 2007
    Alexandria KY
    Good call .....I would'nt put much faith in the waterpump either.
    '67 M715 '42 GPW '45 MB
    I found a 1/2" belt that worked perfectly. It was a totally green gates belt. I think Dave was messing with me, but it worked!
    Tried your account a couple times, but it's not showin pics for me. Anyone else able to see them?
    Jun 2007
    Alexandria KY
    The photos came up for me last night (6-2)....
    Watch those green belts. They are generally for low RPM things like mower decks and the like. They aren't reinforced like conventional belts either.
    Oh, and pics worked for me. Must just be an Iowa thing, Doug......
  1. Air Cleaner Installation help needed...
    By kyken in forum Open Discussion
    Last Post: February 19th, 2010, 09:25 AM
  2. bigkev : installation of fording kit
    Last Post: November 12th, 2009, 02:02 AM
  3. Dash panel Removal / Installation
    By shepsjeep in forum Stock Tech
    Last Post: September 29th, 2009, 09:25 PM
  4. Power Steering Installation Question
    By joesco715 in forum Modified Tech
    Last Post: May 3rd, 2007, 11:25 PM
  5. help! sm465 installation.
    By bggrntrk in forum Modified Tech Archives
    Last Post: May 4th, 2004, 11:21 AM
